The ST165 wheel size thread (offsets, widths, etc)
Postby Toxygene » Thu Jun 05, 2008 5:58 am
So what's the widest wheels that will fit on an ST165 with minimal modifications to the fenders?
Also, what is the perfect offset for the wheels to fit flush?
Toxygene
Postby gpmarzan » Fri Jun 06, 2008 11:11 am
I have 16x7 +38 offset with 205/50 tires. My front left fender started chewing up the edge of my tire. The fender 'unrolled' itself and it was the end of the sheet metal carving thru my tires when I hit bumps on turns. It might be due to alignment issues, I dont know. The other side doesnt do it. Both sides hit the plastic liner.
Patrick M.
st165
gpmarzan
Postby Mafix » Fri Jun 06, 2008 3:25 pm
i'm running 15*7 with a 38 offset
also 16*7 with a 38 offset
both sporting 205 width tires
even with 25mm spacers in the back it doesn't go flush.
Postby 88st165 » Fri Jun 06, 2008 4:34 pm
with my 15x7 team dynamics with 38mm + 15mm spacer in the back its damn near flush, looks awsome imo. good for the street but rubs way way too much for autox. i need to get my rear fenders rolled in a bad way.
oops i forgot to mention that im running 225/50s
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby Mafix » Fri Jun 06, 2008 5:07 pm
oh yeah mine are rolled. forgot about that.
Postby Toxygene » Fri Jun 06, 2008 7:36 pm
Hey Guys,
You might want to post up some side angle shots and top down shots of the fender and wheel combo your running. Along with all the specs on the wheels.
Don't forget to include your tire sizes and if your lowered with a camber kit of any kind.
Toxygene
Postby gpmarzan » Fri Jun 06, 2008 9:52 pm
Enkei GF1 16x7, 205/50, Intrax springs
Patrick M.
st165
gpmarzan
Postby stevo27 » Sat Jun 07, 2008 12:06 am
ill be putting 15x10 on mine i havent figured out how yet but im gonna do it im sure they stick out
No longer a member of the AWD club
just a powerglide and rwd for me
"breaking records and breaking parts go hand in hand"
stevo27
Postby Toxygene » Mon Jun 09, 2008 3:58 pm
gpmarzan wrote:Image
What is the offset of those wheels?
Toxygene
Postby gpmarzan » Mon Jun 09, 2008 6:13 pm
offset is +38
Patrick M.
st165
gpmarzan
Postby Toxygene » Mon Jun 09, 2008 10:47 pm
That front looks absolutely perfect. The rear looks like you could go with an even smaller offset.
You wouldn't happen to have pictures showing the clearances on the inside of the wheel?
Toxygene
Postby ion_four » Mon Jun 09, 2008 10:55 pm
I'm currently running TSW Hockenheim's in 17 x 8" :) I'm actually unsure of the offset, and will need to measure. I've inspected them and they don't appear to have it cast in them.
They are a very high offset, I'd say, since I can't even stick my finger between the rim of the wheel and the adjuster sleeve on my coilovers :)
I have no rubbing issues with 215 series tires and the car relatively jacked-up (I need shorter stroke struts, up front. So, everything is raised to maximize travel, for the time being.) I've lowered it at least half an inch, since the pic was taken, BTW.
99 Prelude:Koni, Neuspeed, GReddy, Jackson Racing, Hondata
77 Celica GT: KYB, Superpro, Megasquirt, Supra
SOLD: 88 Celica Alltrac, 93 Civic EX Coupe, 90 Civic EX
ion_four
Postby gpmarzan » Tue Jun 10, 2008 1:14 am
Toxygene wrote:That front looks absolutely perfect. The rear looks like you could go with an even smaller offset.
Not at the moment, but I will take some tomorrow.
Patrick M.
st165
gpmarzan
Postby quonzilla » Tue Jun 10, 2008 7:10 pm
ill prolly be putty some 205/50/15s on my car...
my shocks are blown.. iam thinking bout upgrading..
i want comfort and a bit lower..
what does everyone sugest?
ive done lots of research... but where can i actually buy these parts.
quonzilla
Postby quonzilla » Tue Jun 10, 2008 7:13 pm
sorry to be more clear...
iam thining bout getting a spring and strut.. ive heard lots good stuff bout whiteline and eibach..
iam interested in TRD too but i hear theres no drop in those springs..
for struts.. iam thinkin kyb?
thanks for ur help!
quonzilla
