ST205 Rear Caliper piston Diameter
Postby Roundy » Thu Dec 11, 2008 7:57 am
As per title.
Wondering what the piston diameter is for an St205 rear caliper.
Cheers
Nathan
Roundy
Postby Dracov » Thu Dec 11, 2008 9:59 am
38.1mm diametre
1988 Toyota Celica Alltrac
Dracov
Postby Gary ST165 » Thu Dec 11, 2008 10:12 am
ST165 turbo 4WD
Gary ST165
Postby Roundy » Thu Dec 11, 2008 7:37 pm
Thank you very much guys!
Through all my searching i couldn't find it anywhere.
Roundy
Re: ST205 Rear Caliper piston Diameter
Postby kilt88 » Mon May 27, 2013 5:17 am
Anyone have a source for these in the USA?
I also need 4 of the metal washers that fit under the mounting bolts.
47731-20230 x4 piston
47795-20020 x4 plate (washer)
Josh
from 185 Performance, many moons ago
92 ST185
Current Project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=46970
Duluth, GA
kilt88
Postby kilt88 » Tue Jul 30, 2013 6:07 pm
It seems these should also work, but I can't find any in the USA...
budweg 233834
centric 146.38020
Josh
92 ST185
Duluth, GA
kilt88
