Koni shox for ST185
Koni shox for ST185
Postby camry90 » Sat Mar 21, 2009 12:54 am
i got a part number for the rear, Koni 8641-1212... i know someone that used it with a ST184 rear casing... but can that shock fit in the 185 rear casing?
camry90
Postby madman » Sat Mar 21, 2009 1:13 am
I am not sure if the regular Celica rear strut inserts will fit or not, but after researching for a while, I ordered the Subaru Legacy/Impreza front strut inserts (part #8610-1318) for the rears that I will be doing in a couple of weeks. I am pretty sure that they will fit, and they do not require any welding.
Tom
WI
st185
madman
Postby camry90 » Sat Mar 21, 2009 1:16 am
madman wrote:I am not sure if the regular Celica rear strut inserts will fit or not, but after researching for a while, I ordered the Subaru Legacy/Impreza front strut inserts (part #8610-1318) for the rears that I will be doing in a couple of weeks. I am pretty sure that they will fit, and they do not require any welding.
nice, please let me know :D
ps. where did you get your source from?
camry90
Postby wyomingtoy » Sat Mar 21, 2009 5:44 pm
I am thinking that the Koni 1211's were for the rear.
wyomingtoy
Postby madman » Sat Mar 21, 2009 10:41 pm
According to this thread, http://www.alltrac.net/phpBB2/viewtopic.php?t=26243, the 1211 are for the front.
I got the front struts (8641-1211) from Twosrus, and the rears (93-98 Impreza front shocks 8610-1318) from Proamauto. Both had the lowest prices, and they shipped them out very fast.
Tom
WI
st185
madman
Postby wyomingtoy » Sun Mar 22, 2009 5:31 pm
Thnaks Madman. I couldn't remember which went where. The 1318's were from the rear. I did not know that they were for an Subaru. They will fit and will go on a ST185 w/o any welding. Just drill the bottom of the old strut. The bottom of the new insert has a bolt welded to it that will fit through the drilled hole and retained with a nut. It is a hand press fit, with a rubber collar to seal between the top of the old strut and the body of the insert.
wyomingtoy
Postby camry90 » Mon Mar 23, 2009 12:32 am
wyomingtoy wrote:Thnaks Madman. I couldn't remember which went where. The 1318's were from the rear. I did not know that they were for an Subaru. They will fit and will go on a ST185 w/o any welding. Just drill the bottom of the old strut. The bottom of the new insert has a bolt welded to it that will fit through the drilled hole and retained with a nut. It is a hand press fit, with a rubber collar to seal between the top of the old strut and the body of the insert.
great! thanks guys
camry90
Re: Koni shox for ST185
Postby celica_gtx » Tue Feb 03, 2015 3:40 am
how do you like the ride with this setup, im looking to do the same.
and how much did you lower the car before the ride became harsh.
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby camry90 » Thu Feb 05, 2015 5:21 pm
i never got around to do it
camry90
