Anyone here ever had their brake master cylinder fail on them when doing a brake change?
I put on the single pot calipers and respective rotors and when trying to bleed them, the system is not leaking but after momentarily building SOME pressure, I lose it. I am sure I bled the system properly cuz I bled all four corners and went through at least a quart of good dot4 fluid! :x
So I took out the brake master cylinder and sure enough, the second (innermost) piston/spring had some corrosion/sign of wear. So I'll be searching for a rebuild kit today.
I just found it strange that since I did not mess with it, that it decided to fail on me just by bleeding my new brakes. :shrug:
Would the brake booster suddenly develop a problem, if there was none before? I'm just trying to attack all the weak links before I get the master back up.
