st205 rear strut fit our 185?
Postby alltracshoak » Fri Aug 07, 2009 9:38 pm
as stated,will the rear st205 strut assembly fit out st185??looks like its the same.only the front strut assembly is different due to the super strut design.im thinking changing my rear end to a st205 with rear 205 brakes since my struts are shot
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby bozo-merlin » Sun Aug 09, 2009 9:25 am
In fact if you plan to put a 205 rear drive train on a 185 you need the rear not to get a lot of camber so yes they fit
but if you only use 205 hub + rear strut on 185 drive train you will get a lot of positive camber.
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Postby alltracshoak » Sun Aug 09, 2009 3:21 pm
no if i plan on doing it i was going to run the whole rear end(subframe,control arm,hub,brake,etc)
what about the fronts??will i be able to change to superstrut if i change te whole fronts(ie spindle,brake,etc)
current:
90 st185
GT4 AWD
alltracshoak
Postby bozo-merlin » Sun Aug 09, 2009 6:42 pm
T20 use a front subframe whereas T18 arm bolt directly on chassis
everything is possible but it really not plug n play
i won't think doing something like this, do you know TTE swap SS for McPherson on the 205
Jérémy
98 RHD SW20 NA
bozo-merlin
Postby alltracshoak » Mon Aug 10, 2009 3:11 am
ok thanks.i think the rears are mcpherson but the fromt are ss
current:
90 st185
GT4 AWD
alltracshoak
Postby Insanity-74 » Mon Aug 10, 2009 9:09 pm
Someone on the GT4OC put an ST205 rear subframe, rear diff etc onto a CS...it was more or less a direct swap but it made the rear wheels stick out about an inch further on each side. Might be worth considering.
http://www.gt4oc.net/forums/viewtopic.p ... 1#p1020611
Insanity-74
Postby phattyduck » Tue Aug 11, 2009 5:52 pm
Insanity-74 wrote:Someone on the GT4OC put an ST205 rear subframe, rear diff etc onto a CS...it was more or less a direct swap but it made the rear wheels stick out about an inch further on each side. Might be worth considering.
The extra 1" to 1.2" per side is perfect for most Alltrac guys - no more 25mm spacer to get the rear wheel well to be filled out!
(I have an ST205 rear subframe, arms and diff on my Alltrac Camry - I got about 3* extra camber with the swap, which I took out with camber bolts. The factory Alltrac Camry rear parts are the same as the ST165/ST185)
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby alltracshoak » Tue Aug 11, 2009 6:18 pm
was it a whole rear end ie(control arms,etc)
or just subframe and the stock camry arms ?iirc by looking at the 205 arms,they are longer
current:
90 st185
GT4 AWD
alltracshoak
Postby Insanity-74 » Tue Aug 11, 2009 7:46 pm
alltracshoak wrote:was it a whole rear end ie(control arms,etc)
Taken from the OC
Next stage was sorting the transmission drone which turned out to be the rear diff so decided to attempt fitting the rear end set up off the st205 mainly because the bushes sit compressed where as the 185 ones have a noticeable gap especially were the diff carrier mounts on the subframe so removed all the 185 subframe,arms,hubs,driveshafts,shockers,etc,everything was removed and compared with st205 equivalent
The conversion uncovered that you can fit the st205 subframe and diff carrier and diff also with no issues ,i.e. straight fit but the 4 arms that run from subframe to hub and the driveshafts are approximately 1 inch longer so would give an approximate 2 inch extra track width if you can be bothered to remove the mounts that secure the torsion bar that runs from hub to chassis and reweld them about an inch wider ,these torsion arms between these 2 models are identical incase anyone wants to know
I did`nt have time to be going as far as this at the moment so compromised on fitting st205 subframe,st205 diff,diff carrier and complete hubs and brakes in conjunction with the stock st185 driveshafts,arms and handbrake cables,fitting what i have mentioned here is all a straight fit that needs no modifications and makes a lot of difference ,ride quality is uncomparable to the oe set up ,a hell of a lot better ,pretty sure people that have driven it will comment on how well it drives and rides ,the car is now a pleasure to drive and a lot more fun
Insanity-74
Postby bozo-merlin » Wed Aug 12, 2009 5:38 pm
phattyduck wrote:The extra 1" to 1.2" per side is perfect for most Alltrac guys - no more 25mm spacer to get the rear wheel well to be filled out!
Agree with that, no more spacer on the rear.
but that's not 1" to 1.2" per side, 185 have 1440mm rear drive width, 205 have 1490, it's 50/2= 25mm
0.98" per side exactly.
As some knows too, spacer on the rear are awfull if the front still stock width on a 185, don't fear to put some spacer in the front to limit undesteering after your rear drive train swap ;)
Jérémy
98 RHD SW20 NA
bozo-merlin
Postby phattyduck » Thu Aug 13, 2009 5:20 pm
The subframe and diff are the same (effectively, if not exactly). The arms add the track width. Make sure you get matching axles if you do this!
phattyduck
Re: st205 rear strut fit our 185?
Postby soarer.jzz30 » Mon Apr 29, 2013 7:02 am
but what would it take to fit the front end suspension wise
soarer.jzz30
