steering racks
steering racks
Postby consume » Sun Nov 01, 2009 10:31 pm
Hi ..i am not sure if this topic has been covered already ..but my question is
do any of you all know..if there are any other steering racks that work for the st185....from other toyota cars ???
consume
Postby Blue91CelicaGT » Mon Nov 02, 2009 4:23 pm
good question.. I was also wondering that myself.
To add to this question is it neccessary to switch to a non-power steering rack when removing your power steering system, or can you simply plug the lines.
90 Red ST185
91 Blue GT
Blue91CelicaGT
Postby Blue91CelicaGT » Mon Nov 02, 2009 4:24 pm
To add to this question is it neccessary to switch to a non-power steering rack when reomoving your power steering, or can you sinply plug the lines.
90 Red ST185
91 Blue GT
Blue91CelicaGT
Postby d1alltrac » Tue Nov 03, 2009 5:52 am
If you just plug the lines you will have an artificial stiffness from the power rack.
We've wanted someone to find a manual rack that fits/works, but no one wants to do the legwork.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby klue » Tue Nov 03, 2009 1:52 pm
I have made a manual rack, costs 475 bucks. Built by the guy who makes steering racks for CASCAR.
Postby d1alltrac » Wed Nov 04, 2009 11:34 am
What ratio is this manual rack? Can he do a custom ratio?
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby sleeper » Mon Nov 09, 2009 6:58 am
It`s not that hard to remove the seals in the st165 rack.. did this on my own in about 2hours.. 0usd solution..
BTW: do anyone know how far of the s205 rack is from fitting in a 185\165?
sleeper
Postby phattyduck » Mon Nov 09, 2009 11:55 pm
sleeper wrote:It`s not that hard to remove the seals in the st165 rack.. did this on my own in about 2hours.. 0usd solution..
The 205 rack mounts vertically from the top on a large subframe instead of the the firewall. It probably won't fit.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby CMS-GT4 » Tue Nov 10, 2009 1:22 am
I am curious if one might just be able to change out the gear in the 185 rack from the one from another toyota, rather than try and figure out an entire rack.
Postby d1alltrac » Tue Nov 10, 2009 8:21 am
I was going to do that with my spare rack. Any special tools needed? Any tips or tricks? I guess I just need to track down that miata write-up.
CMS-GT4 wrote:I am curious if one might just be able to change out the gear in the 185 rack from the one from another toyota, rather than try and figure out an entire rack.
Do you mean to make it manual or to change the ratio? You don't need to mess with any gears to make it manual, just the seals like sleeper mentioned. Changing the ratio I have no idea about, but I'd assume changing gears would do that.
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
Postby sleeper » Tue Nov 10, 2009 9:44 pm
no, no spesial tool needed, pretty straight forward.. just rremember how you took it apart so you can putt it back togetter..
sleeper
Re: steering racks
Postby texturboII » Fri Sep 06, 2013 9:07 pm
Zombie thread!
I'm trying to find a suitable manual rack to swap in myself. Anyone have any luck from an older Toyota?
texturboII
