ST205 rear brakes on an ST185
Postby Toyota_Todd » Sun Jun 20, 2010 7:20 pm
Tried the search and come up with nothing, so here goes...
I have the brake parts to do the 205 swap on the rear brakes of my ST185. Of the members that have done the rear brake swap, did you change out the backing plates or did you just use the stock ST185 backing plates. Any pics or advice would be great and appreciated.
Thanks!
Todd Longenbaugh aka Toyota_Todd
1992 Celica All-Trac Turbo "Seeing Red"
1992 Celica GT-Four RC Conv. "Fatal Alltraction"
2001 Avalon XLS "the wifes family truckster"
1971 Pontiac Ventura II "The token domentic"
Toyota_Todd
Re: ST205 rear brakes on an ST185
Postby 5thgenbliss » Sun Jun 20, 2010 8:51 pm
if you mean the shield then no. I did not replace it. It would require you to take apart your hub in order to replace the shield with a 205. Not sure if it comes off actually. You may have to replace the whole hub with shield. if you were to try and take off the shield, I would probably try and replace the whole hub with a 205 piece.
I just bend the shield back enough to clear the 205 rotors. you also need to shim or create a nice hub spacer ring to bump the centre hub diameter from 54.1mm to 55mm. there are a few ways to do that. do a search.
Boosting with the '92 GT4 RC
5thgenbliss
Postby YerRandO » Sun Jun 20, 2010 9:49 pm
-James
YerRandO
Postby Toyota_Todd » Mon Jun 21, 2010 12:45 am
Thanks for the quick reply and links to more information. Looks pretty straight forward with those instructions. I just need to get them cleaned and then I will get on with the installation.
Toyota_Todd
Postby Cuttyman9 » Mon Jan 07, 2013 4:45 am
Would anything separate this from doing the same on a GT instead of an Alltrac? I was considering the 205 brakes on my car.
1992 Celica GT Hatch
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
Postby toayoztan » Mon Jan 07, 2013 7:09 am
Not sure if it would fit correctly, but I do know your ebrake won't work with the 205 rotors as the internal diameter of the drum portion of the rotor is different.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby Cuttyman9 » Mon Jan 07, 2013 10:08 pm
Ah, so I'd need to "steal" an alltrac's parking brake assembly to make it work or that's Disabled on this swap even on an Alltrac?
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
Postby toayoztan » Mon Jan 07, 2013 10:27 pm
Cuttyman9 wrote:Ah, so I'd need to "steal" an alltrac's parking brake assembly to make it work or that's Disabled on this swap even on an Alltrac?
The alltrac ebrake hardware basically is the same [size] as the 205, so that's not an issue when swapping.
I'm not sure about swapping over the alltrac ebrake stuff to the GT... I guess it depends on the shield (which is what it attaches to), but also if the shield would even fit on the GT knuckle/spindle/hub carrier (whatever you want to call it heh).
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Celicatuner92 » Tue Jan 08, 2013 12:08 am
The sheilds are not simple to replace/change. They are spot welded to the plate the ebrake assembly mounts on which if i remember right is riveted to the rear knuckle under the hub so it is not simple to get to.
90 St185_DD actual car seen on tirerack.com
90 St185_ race car
92 Celica Gt_Runnig
Celicatuner92
Postby Cuttyman9 » Tue Jan 08, 2013 12:14 am
Oh fun fun haha so I think ill look in other areas for rear brake swaps haha.
1971 Cutlass
1967 Chevelle
1975 Trans Am
1966 C20 Long Bed
1999 F150
Cuttyman9
Postby toayoztan » Tue Jan 08, 2013 2:54 am
The shield/ebrake assy plate can be separated from the knuckle, it's just 4 nuts and it slides out. Of course, you need to press the hub out.
The shield and ebrake plate is spot welded together, however, so you'd have to replace the entire thing more than likely or fabricate something.
With all of this, not worth it. I'd look into a different rear brake option too.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby DeeCee » Tue Jan 08, 2013 3:29 am
i cut back the shields on mine to just retain handbrake mechanism.
DeeCee
Postby Insanity-74 » Tue Jan 08, 2013 12:36 pm
As an alternative, IIRC, the whole ST205 rear sub frame bolts straight onto the ST185 (at least it does with the Carlos Sainz) this would give you a slightly wider track too. I know at least one person who has done this, I dont think any modification was needed.
Insanity-74
Postby phattyduck » Tue Jan 08, 2013 4:35 pm
Insanity-74 wrote:As an alternative, IIRC, the whole ST205 rear sub frame bolts straight onto the ST185 (at least it does with the Carlos Sainz) this would give you a slightly wider track too. I know at least one person who has done this, I dont think any modification was needed.
Track goes up by about 60mm total (30mm or 1.2" each side) with the ST205 rear arms. Rear subframes are compatible across all generations. The rear ST205 hub is nice with the brakes because they have the correct 55mm center bore for the brake disc (the wheel center bore is still 54.1mm, the hub has a small step) instead of the full 54.1mm center bore of the earlier (ST185/ST165) cars.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby underscore » Tue Jan 08, 2013 5:12 pm
As I recall it increases rear camber as a consequence, so you'll have to adjust for that.
