aus jd 2703
New member
ok guys i was having brake issued before so i rebuild the master and now the pedal still goes to the floor ive been through two bottles of brake fluid so they're well bled. it seems to be the front right as if i pinch the line the pedal is rock hard so we pulled it apart cleaned it with sand paper and re assembled and yet it doesn't leak the piston moves and still soft pedal.
any ideas? im getting the fronts re built but im not convinced that's the problem??
any suggestions.
ps it seems hard when no booster ie engine off.
any suggestions.
