I never seen that but your right.CMS-GT4":1k04j0ms said:I think he stated in his for sale thread he ended up with the 9.75 version.
Meurz":3nn5dzmu said:Ridiculous fitment, imo.
celicasilfee":3fpk1rk1 said:I'm with UndaGrwnD... what tire size are you running for a stretch like that? And imo, you should lower the car more- stiffen the suspension up tight, & run flush. You have a setup that could pull it off, I think.
UndaGrwnD":okwh8ylp said:so..what are the specs on the wheels now ? do you got the 17x9.75J ? because i liked the concave look...but i was thinking it was the 17x8.25J rims
celicasilfee":okwh8ylp said:I like the looks, but I wish they came in a +30 instead of a +25, cuz I think the extra 5mm into the fender would cause a pretty perfect flush fitment.
Grey_Matter":1056ynjt said:you would have to run at the minimum an 8mm spacer in the rear to run these this wide with an et30...which would probably make the front and rear hellaflush
