So I have been putting thought into rear camber. The problem is when you lower a celica, the rear camber is non adjustable, and lowering it increases it dramatically. This is fine if I only raced the car, but I want to bring the rear into stock specs since this car will be driven on the street as well.
Most use rear camber bolts, and they seem to be a cheap solution, but with a few cons. I have read that they can loose their alignment when driving on rough roads. Also, they create an angle issue on the strut. I had read this can cause additional wear on them. Since my suspension was expensive and I am in no mood to rebuild it any time soon I want to do this right.
I looked into building my own, and there are affordable parts available to do so.
This dsm thread has some good info on it.
http://www.dsmtalk.com/forums/showthread.php?t=223832
another DIY link.
http://www.club202.com/forums/showthrea ... amber-arms
The problem is, where we connect to the spindle we need a control arm bracket. Other than cutting the stock ones and welding I am not sure where we might get these. I sort of want to avoid welding if I can, and make this something that one can either assemble or pick up.
The 205 lower arm would be a possible solution. If one cut it, you might weld on threaded tube ends and use a solid threaded rod to make length adjustment.
http://www.pegasusautoracing.com/group. ... D=TUBEENDS
I started looking into other toyota rear camber arm options, and it seems the MK3 supra has a similar design to the 185. There is already rear arm options for the supra as well. What we have to figure out is if the connecting points are the same, as well as the length. This could be an off the shelf option. We use the supra aftermarket to possibly locate the bracket end too, and possibly build the rest ourselves to keep the cost down.
Here is a camber arm for the mk3.
http://battleversion.com/
Here are images of the MK3, 185 and 205 rear suspension.
another DIY link.
