Porsche Brembo Calipers and STi Rotors
Re: Porsche Brembo Calipers and STi Rotors
Postby alltracshoak » Thu Feb 09, 2012 8:09 pm
thread revive, what are you guys doing in painting???just spray can or powder or???
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby alltracshoak » Thu Feb 09, 2012 8:12 pm
gtfourtc wrote:here are some pics of the gold painted calipers I just finished up.
I did base gold from a company called stove bright its their copper color. Then i used honda inca pearl it was a little darker and had more flake in it. I got my inca pearl from expresspaints.com the will mix any paint code you want and i got it formulated for wheel paint to be a bit more durable. It holds up to the heat as well, I baked on the high heat clear at 500 degrees.
how do you go around baking this? how about the rubber seal by the piston/cylinder that pushes the brake??i just finally picked up some calipers for your brackets, in need of help on how to get this painted and slap them on my car
current:
90 st185
GT4 AWD
alltracshoak
Postby underscore » Sun Mar 04, 2012 7:05 am
whats this about flipping that line over? I just got my calipers this week so I'm trying to prep everything before my rotors arrive.
Postby tubasteve » Sun Mar 04, 2012 8:03 am
putting the line were the bleeders are and the bleeders where the line was......
tubasteve
Postby underscore » Sun Mar 04, 2012 4:38 pm
yes I know that, it just wasnt in the instructions I have so I'm wondering what kind of loctite or sealant I should use on the parts, it looks like there was some on there originally?
Postby tubasteve » Sun Mar 04, 2012 5:16 pm
Its a flare fitting, don't know i would use lock tight.mainly cause it would be a Bitch once dried.
If there was some, it possibly was not lock tight
tubasteve
Postby underscore » Sun Mar 04, 2012 6:02 pm
ok awesome, I'll switch them without anything and if they leak I'll add something.
Postby tubasteve » Sun Mar 04, 2012 9:13 pm
underscore wrote:ok awesome, I'll switch them without anything and if they leak I'll add something.
If they leak, the flared end is messed up.
tubasteve
Postby cederrowe » Sun May 13, 2012 6:38 pm
Are these the same brembo calipers that are on a 06' subaru sti? The reason I ask is I have a full set in my shop with calipers and rotors. Thanks
cederrowe
Postby gtfourtc » Sun May 13, 2012 11:08 pm
those gold calipers pictured are the sti brembos, I repainted them and put them on my 98 forester. The calipers that fit the brackets are porsche 911/boxter calipers
gtfourtc
Postby cederrowe » Mon May 14, 2012 1:06 am
But are they the same mounting wise?
cederrowe
Postby alltracman78 » Mon May 14, 2012 1:09 am
Why the Porsche calipers instead of the ST205 ones?
They look smaller.
Postby underscore » Mon May 14, 2012 1:35 am
cederrowe wrote:Are these the same brembo calipers that are on a 06' subaru sti? The reason I ask is I have a full set in my shop with calipers and rotors. Thanks
The calipers might have different mounting, not too sure but most likely. You could possibly modify the bracket to use the STi calipers. Also you'll have to redrill your rotors.
Postby phattyduck » Mon May 14, 2012 4:47 pm
cederrowe wrote:But are they the same mounting wise?
No. The Porsche calipers are radial mount, which is why they work so well for 'aftermarket' use. The Subaru Brembos have custom mounting ears that are meant for Subaru only.
alltracman78 wrote:Why the Porsche calipers instead of the ST205 ones?
They look smaller.
The Porsche calipers are smaller - and that's the point. They have similar (if not better!) braking performance and a smaller body to fit under wheels. At the same time, because they are radial mount, you can fit them to the car more easily once you have the correct bracket.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby cederrowe » Mon May 14, 2012 6:11 pm
Cool thanks fort the info geuss ill just keep them for a subie project.
cederrowe
