Front sway bar size?
Postby woot woot » Fri Nov 04, 2011 11:23 pm
Hey everyone,
I have been having trouble finding the size of the front sway bar on my JDM185. I want to replace the bushes and seem to get the sizes 26 or 27 or 28mm from people with no real answer.
Can anyone help?
woot woot
Re: Front sway bar size?
Postby CMS-GT4 » Fri Nov 04, 2011 11:48 pm
Go to toyodiy.com and look up your model and you can find the part numbers for the bushings. I know there were different sway bar sizes for 90-91 and 93-93 in the US, but not sure what the rest of the world got.
Postby woot woot » Sat Nov 05, 2011 4:31 am
Cool thanks for the help. i found the part number 48815‑20230, but wanted it in Polyurethane. But will try and track this down
woot woot
Postby Hotrodhendrix » Wed Oct 10, 2012 7:08 pm
Bringing it back from the dead but mine will not pull up on there. Was size are the 90-91 and 92-93 USDM front swaybars?
~James
Postby underscore » Wed Oct 10, 2012 7:27 pm
Just grab a bunch of big wrenches, and see which is the smallest you can fit around the bar. If you don't have big enough wrenches, use an adjustable one, tighten it down around the bar, take is off and size up two smaller wrenches to find the size. Use the open ends of the wrenches and press the two inside flat edges together to be sure you're measuring it accurately.
