94 MR2 Turbo
Member
I was wondering if anyone else has had these issues like I have. Ive been doing wheel bearings ever since I bought this car 2-3 years ago. Total Ive replaced about 7 total in all four corners. recently i had my car on a dynopack dyno and I belive this just made it wear out even faster.
Is this a common problem?
Im using oem bearings and hubs. Lowered on Ksport coilovers, whiteline swaybars and oem bushings 17x9 et30 do you think that my offest has anything to do with my issues? should i raise it so high that I have more nutral load on these bearings? Is there a upgraded bearing that I could use?
this last bearing that went bad lasted for 7k miles. I hope someone has some insite on this.
