All Trac brakes vs GT4
Postby jerod » Sat Mar 03, 2012 3:20 am
:D Hi guys, i was just wondering if the all trac brakes are the same as the GT4? on my 91, i have twin piston design for the front and single piston in the rear. Does the all trac have the same design or are my brakes jdm only.Thanks for the help,my rear brakes are shot(metal to metal) and i might as well do my fronts.Thanks again guys for any help.
jerod
Re: All Trac brakes vs GT4
Postby l0ch0w » Sat Mar 03, 2012 4:19 am
All ST185 brakes are the same. the RC or CS brakes are no different.
If you want to upgrade, look at getting a set of ST205 brakes.
Andrew
1991 Red Alltrac
l0ch0w
Postby athousandleaves » Sat Mar 03, 2012 4:37 am
Some very early ST185's did receive the ST165 setup with the twin piston and 255mm rotor.
If you are trying to get parts tell them to look up the 165 and it will be perfect.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby tubasteve » Sat Mar 03, 2012 5:02 am
didnt think the 91's got the old 165 setup, thought it was early 90 model only, huh...
anyway.
alltrac/rc/cs
279MM rotor
yours
"255mm"
tubasteve
Postby BoostedBlueToyotas » Sat Mar 03, 2012 2:56 pm
And I believe its not as effective as the later ST185 setup anyways ....
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby underscore » Sat Mar 03, 2012 3:49 pm
athousandleaves wrote:Some very early ST185's did receive the ST165 setup with the twin piston and 255mm rotor.
are they noticeably smaller? my friends 185 narrowbody has visibly smaller brakes than me and we can't figure out what to replace them with.
Postby athousandleaves » Sat Mar 03, 2012 4:18 pm
I think the 185 setup benefits mostly from a larger rotor used with the massive single 50mm piston caliper.
http://www.gtfours.co.uk/pics/brakes/brakes.htm
Go there for more pictures ^^^
1992 White turbo4WD
athousandleaves
Postby jerod » Mon Mar 05, 2012 2:57 am
Thanks guys for your quick answers and pics :D So I have to order the st165 front brakes and st185 rear brakes or st165 rear brakes? Thanks again guys,THIS SITE IS AWSOME!!!! :notworthy:
jerod
Postby underscore » Mon Mar 05, 2012 5:33 am
thank you sir, those pictures are a huge help.
Postby athousandleaves » Mon Mar 05, 2012 6:37 am
Gary ST165 wrote:
Front
ST165/early ST185/JDM - 256mm x 25mm vented >54.1mm ID
ST185 - 277mm x 25mm vented >54.1mm ID
ST205 -315mm x 32mm vented >55.0mm ID
Rear
ST165/early ST185/JDM -269mm x 16 ?? mm solid >54.1mm ID
ST185 -288mm x 16 ?? mm solid >54.1mm ID
ST205 -315mm x 16mm vented >55.0mm ID
1992 White turbo4WD
athousandleaves
Postby bmt » Mon Mar 05, 2012 6:56 am
Just to add to the confusion very early jdm St165s had a single piston front caliper as well!
bmt
Postby tubasteve » Mon Mar 05, 2012 5:19 pm
athousandleaves wrote:ST165/early ST185/JDM - 256mm x 25mm vented >54.1mm ID
165 are 269x*10* 59.8 high
St185 are 288x*10mm* 60 mm high
Both solid
Quote its Gary's
tubasteve
Postby eilie992 » Sat Feb 02, 2013 3:17 pm
Great info and good pics, but I need to make sure I'm understanding correctly. I have a 185 that I'm pretty sure is an early model with the 165 brakes and am looking to replace/upgrade. I've heard a lot of people say to upgrade from the single piston calipers of the late 185s to the 205s. If I've got the 165 brakes, can I still upgrade to a set of 205s or even the late 185s?
eilie992
Postby Corey » Sat Feb 02, 2013 3:23 pm
Yes. Same hub and Knuckle as the later spec 185. My car also had 165 front brakes and I've since upgraded to a ST185 aftermarket bbk.
Corey
Images: 50
Postby fussellbug » Sat Feb 02, 2013 5:57 pm
your most simple upgrade would be to buy later model ST185 calipers, brackets and rotors to replace your two piston setup. This will bolt up directly to your car with no additional modification. If you're looking to have dramatically improved braking, there are big brake kits available for varying costs or the St205 brakes can be fitted after making some modifications.
fussellbug
Images: 36
