Brembos & 5x114.3?
Brembos & 5x114.3?
Postby underscore » Wed Mar 14, 2012 8:19 pm
tubasteve is working on a rotor that would fit with the Porsche adapter. I'm trying to learn as much as I can about the dimensions involved so I can be of some help here. I have a feeling a 2004 G35 rotor would work with a spacer someplace, but I don't know enough to be sure. To compare:
1996 Rav4:
Brake Rotor/Disc Bore Diameter (mm): 62.04
Brake Rotor/Disc Initial Thickness (mm): 17.899999
Brake Rotor/Disc Outside Diameter (mm): 301.8
Brake Rotor/Disc Overall Depth (mm): 46.3
2004 Camry:
Brake Rotor/Disc Initial Thickness (mm): 28
Brake Rotor/Disc Outside Diameter (mm): 275
Brake Rotor/Disc Overall Depth (mm): 49
2004 G35 Coupe:
Brake Rotor/Disc Bore Diameter (mm): 68
Brake Rotor/Disc Initial Thickness (mm): 30
Brake Rotor/Disc Outside Diameter (mm): 324
2004 STi:
Brake Rotor/Disc Bore Diameter (mm): 58
Brake Rotor/Disc Outside Diameter (mm): 326
Brake Rotor/Disc Overall Depth (mm): 52.7
1992 Alltrac:
Brake Rotor/Disc Bore Diameter (mm): 54.14
Brake Rotor/Disc Initial Thickness (mm): 24.9
Brake Rotor/Disc Outside Diameter (mm): 276.899999
Brake Rotor/Disc Overall Depth (mm): 46.15
All measurements from Autozone.com, if you have a better source let me know.
So if I'm reading this right, the G35 rotors will fit with the Rav4 hub, a small spacer to move the caliper slightly, a new rotor alignment spacer, and the Brembo adapter brackets, while losing 2mm total diameter off the rotor? Or does that difference in overall depth mean my Brembo adapters will land the caliper in the wrong spot on the G35 rotor?
Re: Brembos & 5x114.3?
Postby tubasteve » Wed Mar 14, 2012 8:39 pm
ive ordered my caliper, should be here today, or first thing in the morning.
-jr
edit************
they are out of stock at the moment.
tubasteve
Postby underscore » Thu Mar 15, 2012 6:59 pm
I'm thinking of trying to contact brake rotor companies to see if their systems can search for a rotor based on our required parameters. So I'll need to know, what are the "ideal" dimensions of a rotor for us?
Would it be:
Brake Rotor/Disc Bore Diameter (mm): 62.04 (minimum) Rav4
Brake Rotor/Disc Initial Thickness (mm): 28-30 Boxter S
Brake Rotor/Disc Outside Diameter (mm): 326 STi
Brake Rotor/Disc Overall Depth (mm): 52.7 STi
Better dimensions:
2004 STi
1997 Rav4
2004 G35
2004 Camry
1992 Alltrac
Postby RafaCalde » Sat Mar 17, 2012 2:42 am
how much do the stock rotors weigh?
Rafa
RafaCalde
Postby temperacerguy » Sat Mar 17, 2012 3:11 am
um... look at your question... then look 3"s up.
temperacerguy
Postby tubasteve » Sat Mar 17, 2012 4:12 am
17.5 lbs btw....just wt mine.
tubasteve
Postby RafaCalde » Tue Mar 20, 2012 3:27 pm
temperacerguy wrote:um... look at your question... then look 3"s up.
Sorry, I was reading too fast and didn't pay attention.
Rafa
RafaCalde
Postby tubasteve » Tue Mar 20, 2012 3:43 pm
OFF WITH HIS HEAD!
Just kidding.
-jr
tubasteve
Postby underscore » Tue Mar 20, 2012 4:21 pm
tubasteve wrote:ive ordered my caliper, should be here today, or first thing in the morning.
-jr
edit************
which caliper did you order? I don't have a spare hub to work with so it may take me a while to start aquiring parts.
Postby tubasteve » Tue Mar 20, 2012 6:52 pm
I haven't ordered yet, I'm worrying about other problems right now as you know. As soon as i find what I'm looking for you will know.
-jr
tubasteve
Postby RafaCalde » Wed Mar 21, 2012 12:43 am
Has anyone ever thought of using EVO brakes? I've of doing that myself. For the front at the very least.
Rafa
RafaCalde
Postby underscore » Wed Mar 21, 2012 1:02 am
what gen? I think I checked into it, but the dimensions were way off.
Postby tubasteve » Wed Mar 21, 2012 1:24 am
I have the rotors....evo 9, too flat, hub is huge.
-jr
tubasteve
Postby RafaCalde » Wed Mar 21, 2012 4:05 pm
I see. Well I thank you for information. I'd like to make my own kit using another vehicles setup, something similar to what you're doing. I'll just have to figure that out myself as you are doing.
Rafa
RafaCalde
Postby underscore » Wed Mar 21, 2012 4:21 pm
the easiest way will be what we're trying to do right here, but it all depends on how custom you're willing to go.
