with the g35 rotor you would actually need to shave to bracket down about 3.6mm any local machine shop could handle this, but they can charge 50-100 dollars shop rates per hour, if those of you that want to swap to the 5x114 hubs go with the g35 rotor i can modify your brackets to work, and get you new rotor centering rings as well.
I will keep searching rotor dimensions and maybe something else will come up that is just right.
actually just remembering the toyota supra rotors they are a better option than the g35 since the have the correct hub register already, only thing needed is to shave the brackets.
