Review eBay Spacers $65 Shipped!!
Postby celicat93 » Wed Jul 18, 2012 1:35 pm
I just ordered and received a pair of 25mm spacers that I bought from eBay. I had a friend of mine who's a machinist look at them and he said they're very high quality. The nuts (edit: nut threads, I should say) are formed rather than cut, making them stronger, all the machine work is clean and precise.
Seller: Precision European Motorwerks, pe-motorwerks( 11998)
These are the ones I ordered, suggested by the manufacturer for Celicas made from 1986-2009.
http://www.ebay.com/itm/2-25mm-5x100-Hubcentric-Wheel-Spacers-Toyota-Camry-Celica-Corolla-Matrix-1-/380452674273?pt=Motors_Car_Truck_Parts_Accessories&hash=item5894bf1ae1
celicat93
Re: Review eBay Spacers $65 Shipped!!
Postby celicat93 » Wed Jul 18, 2012 1:38 pm
PS - it looks like they make their own shock absorbers, I wonder if they could make rears for us?!?
celicat93
Postby Hotrodhendrix » Sat Jul 28, 2012 8:06 pm
Just ordered mine for 59.99 shipped. 20mm :)
Postby CMS-GT4 » Sat Jul 28, 2012 8:34 pm
I was looking at these for my rear 5x114 setup.
Postby celicat93 » Sat Jul 28, 2012 8:43 pm
I asked them if they'd do a run of shocks for us and they said they're moving away from doing shocks. They wouldn't even consider a group buy. :x
celicat93
Postby CMS-GT4 » Tue Jul 31, 2012 3:39 pm
They do not make a hubcentric 5x100 to 5x114 adapter. They also told me they will not do custom orders. So I guess I will get my adapter elsewhere.
Postby Hotrodhendrix » Tue Jul 31, 2012 5:11 pm
Sounds like they are trying to become more of a main stream parts producer and not a "machine shop" or custom type shop..
Atleast they will save some of us spending so much on spacers.
~James
Postby celicat93 » Tue Jul 31, 2012 5:50 pm
Hotrodhendrix wrote:Sounds like they are trying to become more of a main stream parts producer and not a "machine shop" or custom type shop..
~James
Works for me!
celicat93
Postby CMS-GT4 » Thu Nov 08, 2012 3:51 am
Did the 25mm spacer studs sit flush or below the spacer or do you need wheels with holes inside to fit them. I know their 20mm needs wheels that are compatible.
Postby 2RM » Thu Nov 08, 2012 10:14 am
I have 16'' wheels with 255/50 tires. Offset is +35, I pretty sure. I wanted to get some spacers for the rear for a long time! If I put 20mm spacers, do I need to roll the quaters???
2RM
Postby Hotrodhendrix » Thu Nov 08, 2012 11:46 am
CMS-GT4 wrote:Did the 25mm spacer studs sit flush or below the spacer or do you need wheels with holes inside to fit them. I know their 20mm needs wheels that are compatible.
25mm sit flush so compatible wheels are not required.
2RM wrote:I have 16'' wheels with 255/50 tires. Offset is +35, I pretty sure. I wanted to get some spacers for the rear for a long time! If I put 20mm spacers, do I need to roll the quaters???
Im running 25mm spacers with 18x8 rims 235 35 18 tires offset of +35. Mine were already rolled before instal but it looks like without they would have needed to. I would for safe measure.
~James
Postby polm » Thu Nov 08, 2012 3:30 pm
I was looking at these last week, I'm glad to see they're good. Thanks!
polm
Postby CMS-GT4 » Thu Nov 08, 2012 4:10 pm
Thanks hotrod. My winter wheels can't clear my new brakes.
Postby Hotrodhendrix » Thu Nov 08, 2012 4:49 pm
CMS-GT4 wrote:Thanks hotrod. My winter wheels can't clear my new brakes.
Just make 100% sure your wheels are compatible with a 20mm spacer first... That was an annoying ordeal. :P
~James
Postby CMS-GT4 » Thu Nov 08, 2012 4:53 pm
I'm going to put 25mm on the front. Then I am getting 100 to 114 adapters made for the rear.
