rack upgrade?
rack upgrade?
Postby heller » Tue Sep 18, 2012 3:04 pm
my rack is leaking bad and i wat to replace it , just checking if there is any uprades out there or a certain brand that is most durable. thanks
91 clelica gts gen 2 3sgte swap , 5spd, gt3076r,hks bov hydra nemesis 2.7 , wiseco pistons, eagle rods, 880cc injectors, 270 degree kelford cams.
heller
Re: rack upgrade?
Postby toayoztan » Tue Sep 18, 2012 8:57 pm
You can buy an OEM reman rack directly from Toyota for 240. It comes with new inner tie rods and boots (which are expensive in of itself).
In fact, directly from Toyota, the inner tie rods are 128 a piece online, and boots and hardware is 35 per side.
That alone is obviously more than a complete reman. rack with everything except the outer tie rods.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: rack upgrade?
Postby underscore » Tue Sep 18, 2012 9:02 pm
^ wow, that's great info to have!
Re: rack upgrade?
Postby klue » Tue Sep 18, 2012 11:34 pm
where do you get a reman rack for that price?
st165 too ? :)
Re: rack upgrade?
Postby Hotrodhendrix » Wed Sep 19, 2012 11:56 am
Thats not too bad. I deleted mine and depowered the rack correctly... Still too heavy for my liking.
~James
Re: rack upgrade?
Postby heller » Thu Sep 20, 2012 2:46 pm
ok i found a cardone reman with inner tie rods on rock auto parts website for 152.79 plus 75.00 core, and a ATSCO reman for 198.99 plus $56 core charge, this is for the gts tho, not alltrac, if that makes a difference. dont know about the quality but i think il get one of these.
heller
Re: rack upgrade?
Postby toayoztan » Thu Sep 20, 2012 4:34 pm
The part came from www.1sttoyotaparts.com and there is a $150 core charge. So up front, the cost isn't cheap, but obviously you'll return your old PS rack, assuming it's still in rebuildable condition for them.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
