How to install st205 brakes???
Postby alltracst185 » Tue Oct 02, 2012 9:02 pm
Help a long time alltrac.net member and st185 owner out :D
Ok, I searched with no luck :( I just ordered st205 front and rear brakes, I know the rears bold on with no trouble. Now the fronts, I read way back that they require a spacer of some sort? what rotors can be used? Thanks in advance :D
alltracst185
Postby Meenya » Tue Oct 02, 2012 9:08 pm
Can't tell you much about fronts. But for rears you want somehow to close the gap between the hub and rotors.
Stock ST185 hub is 54.1mm but the ST205 rotors designed for 55mm. Hope that helps.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Re: How to install st205 brakes???
Postby ALLensTRAC » Wed Oct 03, 2012 2:50 pm
Take a look at the thread 25 posts down from this one. Its the 14 page thread on 205 fronts. They say the only way to do it with the original 205 rotors is to have them machined down to 307.5mm diameter. Also you will have to run a centering ring in the front as well. Bozo-merlin did it with 330x32 rotors but the calipers have to be mounted down on the rotor close to the ball joint so that there is room for a bracket. I would just wait until you have parts in hand and find your own solution. It looks as though there are many ways to do it. Hope it helps,
Allen
Allen
ALLensTRAC
Postby CMS-GT4 » Wed Oct 03, 2012 3:02 pm
There are too many ways to do it, which is why that thread is so large. I think the easiest is likely the gt4oc kit that lets you use wrx discs. No matter what you do, there is some work ahead for you.
Postby alltracst185 » Wed Oct 03, 2012 9:16 pm
Damn! I thought this was the easiest solution to a BBK :| No one has made a bolt on kit for this yet??
alltracst185
Postby CMS-GT4 » Wed Oct 03, 2012 9:23 pm
There have been a few attempts. Some had issues. There was actually a japanese bolt on kit for the 7th gen, that could likely work on the 185, but it would cost you likely over $800 just for the kit.
If you have the 205 rotors, you will still need to sort out a spacer, and grind some off the caliper ear as well as get the rotors milled down. Check Ripley's setup for info on that. I am still trying to sell my calipers. If I kept them, I think I would have had new mounting holes drilled into the upper part of the ears, then cut so that I can use a custom bracket. I opted to use gtfour77s kit since it was a bit more geared for my goals and 5x114 setup. I think there being so many options for what to do with the brakes makes it harder to decide how to approach the 205 setup.
Postby WarTowels » Wed Oct 03, 2012 9:43 pm
I think it's possible to use 205 rotors un-milled. Pretty sure I have seen that done, that is what I will attempt if I ever get that far.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby DeeCee » Thu Oct 04, 2012 12:56 am
The issue is the offset of the rotor and inteference with the ball joint hence spacer behind rotor. Then caliper location to disc has to be offset mounted to st185 hub carrier caliper mount points. Easiest thing to do is buy off the shelf or build a custom kit. I went through options looked at other calipers and rotors and ended up with wilwwod calipers and wrx 324mm discs. If you really want st205 calipers then you have to machine caliper mounts and use supra disc redrilled and a hubcentric spacer on the hub spigot
DeeCee
Postby loudstealthGT-Four » Thu Oct 04, 2012 8:57 am
Having just done the ST205 Front Calipers on my 185, I wish I'd have just bought the wilwood kit from http://www.mrpltd.co.nz/product/53/coro ... 16-22.html, He does a kit for the ST185 and although is abit more expensive, would be well worth it for the ease of installation and replacement parts.
Doing the ST205 calipers I had to...
Buy JZA80 Supra Discs
Re-drill discs to 5x100 stud pattern
Machine Hub rings to locate discs
Grind 4-5mm of Caliper Ears/ mounting points
Fit wheel spacers to fit wheels
Probably ended up spending close to $1200-1300 NZD, definitely wasn't as straight forward as I thought when I first started.
loudstealthGT-Four
Postby 4rsnduction » Thu Oct 04, 2012 10:06 am
I checked the link but couldn't find the kit he dose for the ST185
4rsnduction
Postby DeeCee » Thu Oct 04, 2012 11:00 pm
Mrp aka Barry and i worked on getting the kit right for the st185. Check my project thread for the discussion on it. Not on website as it is a 'build as required' kit. Small business so he doesn't hold heap of stock especially custom stuff. Will do photo and cost stuff some time later.
DeeCee
Postby alltracst185 » Sat Oct 06, 2012 7:44 pm
Anyone ever try 04 STI rotors?
alltracst185
Postby loudstealthGT-Four » Sat Oct 06, 2012 9:18 pm
alltracst185 wrote:Anyone ever try 04 STI rotors?
They are the wrong height and would foul on the lower ball joint, would require a spacer behind the disc, like the ST205 disc.
loudstealthGT-Four
Postby underscore » Sat Oct 06, 2012 9:42 pm
I have 04 STi rotors and they seem to clear everything, but just barely.
Postby alltracst185 » Sun Oct 07, 2012 12:35 am
underscore wrote:I have 04 STi rotors and they seem to clear everything, but just barely.
Are you using ST205 calipers?
alltracst185
