Aggressive outer and inner tire wear after a season
Postby celigts » Mon Oct 08, 2012 7:43 pm
Could someone give me ideas as or things to look at about why my front tires wore out so fast! Used the 1.5 summers and just the outer and inner fronts went to crap.
Shocks have been on there way out and now I see my sway bAr end link is toast on the drivers side.
Thanks
3SGTE project motor very slow
celigts
Postby celigts » Mon Oct 08, 2012 8:40 pm
celigts
Re: Aggressive outer and inner tire wear after a season
Postby 88gt4DE » Mon Oct 08, 2012 8:57 pm
Have you checked front end parts ? Tie rods ? Ball joints ? etc , etc
Postby celigts » Mon Oct 08, 2012 9:08 pm
No I haven't. I don't know how to check or what to look for as to damage so I haven't done that.
celigts
Postby Awesome-Trac » Mon Oct 08, 2012 9:23 pm
This looks like a over inflated tire where only the side walls wear faster before the center
•Daniel
Awesome-Trac
Postby DTE » Mon Oct 08, 2012 10:30 pm
Awesome-Trac wrote:This looks like a over inflated tire where only the side walls wear faster before the center
Under inflated wears the outsides over inflated wears the center.
Devin
88 Celica All trac
DTE
Images: 5
Postby esracing » Mon Oct 08, 2012 10:40 pm
tooo low psi .in the tires you should run 35 to 38 ,and rotate every 5k
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby celigts » Mon Oct 08, 2012 11:17 pm
Ill check my pressure. I haven't really checked often. I gauge it by how low it lays on the ground from the sidewall.
Would anything mechanical cause anything like this?
celigts
Postby Mafix » Mon Oct 08, 2012 11:32 pm
yes a good check of the front end and more dilligent maintenance. one of the perks of owning a sports car.
Postby celigts » Tue Oct 09, 2012 12:10 am
Yea still learning. Ill just have to get a decent pressure gauge and keep it handy. Sounds like its pretty much all about tire pressure in this case
celigts
Postby ALLensTRAC » Tue Oct 09, 2012 12:52 am
Has the car been on an alignment rack recently? Most shops will charge a small fee to check the alignment without adjusting it(my shop is only a half hour labor verse 1.8 hours with the full adjustment FYI). It also looks as though they're pretty well worn out just more so towards the edges. Take what Mafix said to heart. Owning a sports car(especially one thats 20 years old) requires constant small checks to keep from creating expensive problems. Tire pressure is number one on that list. Remember that your tires are the only thing connecting you to the road. Keep your pressure around 35 psi and rotate the tires every 3000 miles. Have an alignment check done at least once a year. Its amazing how fast poor alignment angles can destroy a set of tires.
Good Luck,
Allen
Allen
ALLensTRAC
Postby celigts » Tue Oct 09, 2012 2:58 am
Thanks for the feedback and ill schedule an alignment to be done. My friend over the weekend suggested that as well cuz personally never had it done and didn't know it should be a routine thing. Would tire pressure be the same front and rear then abouts?
celigts
Postby 4rsnduction » Tue Oct 09, 2012 4:11 am
You should have your alignments checked and adjusted by a professional every time you get a new set of tires or when you notice erratic wear on the tire face.
toes in/out is the major adjusting point
camber and caster are not directly adjustable with a stock suspension setup but changing the toe values can alter the camber/caster values but a minor amount.
4rsnduction
Postby Awesome-Trac » Tue Oct 09, 2012 4:23 pm
Thank you sir for the correction, lol I was actually mounting a tire while wrote this with the similar problem
•Daniel
Awesome-Trac
Postby underscore » Tue Oct 09, 2012 4:37 pm
celigts wrote:Ill check my pressure. I haven't really checked often. I gauge it by how low it lays on the ground from the sidewall.
Low pro's or any stiff sidewall tire won't really show that it's low until it's getting extremely low, my old tires didn't look any different until they got down below 15psi.
