Hydraling handbrake upgrade
Postby Killtodie » Thu Nov 22, 2012 7:34 pm
My ST165 is missing all the handbrake hardware, no one sells the kits and from the dealer its going to cost me $200 to replace the hardware.
I wanna install a hydraulic handbrake but keep my existing center console and hand brake lever. This seems like a cheaper and better solution.
Any examples of hydraulic handbrakes that keep the existing center console intact?
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: Hydraling handbrake upgrade
Postby fussellbug » Thu Nov 22, 2012 10:04 pm
I believe you can still get the parts you need from Rockauto.com
Spring kit - Wagner H10369 - $3.73
Hold Down Kit - Wagner H14066 - $2.95
Wheel Cylinder (LH) - Wagner WC107464 - $5.98
Wheel Cylinder (RH) - Wagner WC107465 - $6.73
Parking brake Pads - Wagner PAB529 - $9.45
Adjuster Kit (LH) - Dorman HW12502 - $12.40
Adjuster Kit (RH) - Dorman HW12503 - $11.35
I think that's all the hardware you'd need to put the parking brakes completely together.
fussellbug
Images: 36
Postby Killtodie » Thu Nov 22, 2012 10:10 pm
Sorry, but those are incorrect parts. They are for rear drum brakes, not the rear drum hand brake. There are no wheel cylinders involved, instead there are cable actuators that I'm missing, 4 piece, Toyota wants like $80 per wheel. Rockauto does sell rear drum brake pads and they are like $40. Some of the hardware kit will work but I'm missing everything else that's hard to come by.
Killtodie
Postby gearhead313 » Fri Nov 23, 2012 7:33 pm
That will be all custom. You'll have to figure out how to actuate a mini master cyl with the stock hand brake handle.
this is usually where you'd start:
http://www.cncbrakes.com/images/402.jpg
you can also get set brake solenoids to blow the rear brakes (or all) for parking, but they can bleed off.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby Killtodie » Fri Nov 23, 2012 7:41 pm
Right, I can buy a hydraulic hand brake with a actuator for like $170. Or make my own I guess, I have access to a CNC machine.
Just wondering if anyone has done something like this so I can reference.
Killtodie
Postby underscore » Sat Nov 24, 2012 6:04 am
why not get the parts used or from a cheaper supplier like Lithia?
Postby Killtodie » Sat Nov 24, 2012 8:41 pm
Never heard of Lithia. Got a link? not finding it via google.
plus, a hydraulic handbrake would be nice.
Killtodie
Postby underscore » Sat Nov 24, 2012 10:49 pm
Postby Killtodie » Sat Nov 24, 2012 11:35 pm
yeah, not cheap and dont even see the parts needed. wheel cylinder is $60 each. wow, those are like $14 on rock auto.
Killtodie
Postby lumbercis » Sun Nov 25, 2012 4:25 am
Between not having a handbrake and spending $200 to fix your handbrake, I'd spend the $200. :shrug:
You're not going to come up with a completely custom solution for less money than that unless you have godlike fab skills.
Caldina powered...
lumbercis
Postby Killtodie » Sun Nov 25, 2012 6:03 am
I'm just going to get a hydraulic hand brake. I can buy one for like $120 with stainless steel lines.
Killtodie
Postby MWP » Thu Nov 29, 2012 2:43 am
Killtodie wrote:I'm just going to get a hydraulic hand brake. I can buy one for like $120 with stainless steel lines.
Dont.
There is a VERY good reason why hydraulic handrakes are not used on factory cars.
They leak & eventually fail.
Fix up the stock cable system.
Postby Killtodie » Mon Jan 07, 2013 10:02 am
Dont.
They leak? They just hook up to your existing lines, use proper hardware and you will be fine.
The one I'm looking at is more than halfway down the page here
http://www.gtfactory.jp/cms/page.php?4
Killtodie
