TRD Struts for ST185
Postby Tecker185 » Mon Dec 10, 2012 11:44 pm
Has anyone herd of these or came across a set? I just bought a parts car and the PO claimed most of the parts on the car were removed from an RC.
I got tearing into the car and the struts were green. I thought that was odd so i cleaned them up in search of a part number. The say TRD a part number and KYB. They also have adjustable dampening.
The rears a leaking and so is one front. I hear you can get struts rebuilt. The front would be easy because the tops unscrew, but how would you do the rears they are welded. Has anyone had a strut rebuilt?
I will post pics later of the front struts when i get home and list the part number.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Re: TRD Struts for ST185
Postby CMS-GT4 » Tue Dec 11, 2012 12:14 am
I have seen these for sale on the forums from time to time. I would contact KYB and see if they would rebuild them.
Postby Overtriped » Tue Dec 11, 2012 1:05 am
There is also A thread on here about cutting and welding on a threaded nipple so you can rebuild them like the fronts.
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Postby Tecker185 » Tue Dec 11, 2012 3:00 am
I'd like to rebuild them because there cool. I've been told there is local shop that rebuilds them.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby athousandleaves » Tue Dec 11, 2012 4:08 pm
I just put my non-adjustable TRD's on for winter and to be honest I like them much more for the street than my teins!
Fantastic dampening and spring rate but you don't have to creep over speed bumps too much or dodge every pothole you see.
Definitely happy with mine so rebuilding yours will be well worth it imo.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby Tecker185 » Fri Dec 14, 2012 3:16 am
Part numbers are-
48510-STB81 front
48540-STB81 rear
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby Tecker185 » Sun Dec 16, 2012 3:08 am
Also what is sweet is the rears unscrew at the top like the fronts do. So if I can't get them rebuild I can't put new cartridges in.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
