Temporary ABS Disable?
Postby MWP » Thu Dec 27, 2012 4:39 am
Hi all,
I want to keep ABS for street driving, but want to disable it when on the track.
Is it as simple as pulling the ABS fuse or cutting power to the ABS system?
When power is cut, do the brakes act like they would in a non-ABS equipped car?
Re: Temporary ABS Disable?
Postby underscore » Thu Dec 27, 2012 9:30 am
Any kind of fault in the ABS system should shut it off, I'd imagine having the fuse tied to a switch would do it.
Postby Killtodie » Thu Dec 27, 2012 9:48 am
Pulling the fuse should do it. Not an expert on most systems but I assume ABS systems are designed to allow the brakes to work when the ABS module is not. So, pulling the fuse should do it.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Postby Hotrodhendrix » Thu Dec 27, 2012 1:20 pm
Pull the fuse. Kick panel by drivers feet I believe
~James
Postby MWP » Thu Dec 27, 2012 1:28 pm
Ok thanks guys.
I just wanted to make sure pulling the fuse/power did the right thing.
Im actually going to wire in a ECU controlled relay to disable ABS when in "track-mode".
Postby Corey » Thu Dec 27, 2012 3:53 pm
There is an Abs fuse in the main engine bay fuse box. Pull that and it will disable it.
Corey
Images: 49
