Rear brakes keep seizing
Postby Killtodie » Mon Jan 07, 2013 8:33 am
2nd time my rear caliper has seized up and does not release all the way, is there a helper spring that I might be missing?
I'll take it apart again, clean and relube everything again.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: Rear brakes keep seizing
Postby toayoztan » Mon Jan 07, 2013 8:38 am
Killtodie wrote:2nd time my rear caliper has seized up and does not release all the way, is there a helper spring that I might be missing?
Rear brake, you are referring to the caliper right? (I know you said it, but just making sure you aren't talking about your ebrake which does not use the rear caliper)
If the rear caliper, then no, there is no helper spring, it's purely a hydraulic set up.
If it is seizing, more than likely the caliper needs to be rebuilt or you need to buy a new one (overhauled from auto store). Mine had seized once, and I couldn't even press the piston back in.
When you are taking it apart and relubing things, what are you doing exactly?
You would need to go as far as taking the piston out, make sure there inside is clean, get new seals, etc (aka rebuild it).
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby Killtodie » Mon Jan 07, 2013 8:56 am
The disc caliper, not the drum brake stuff.
When I rebuilt it, I took out the bolt, wire brushed it, cleaned everything with brake cleaner, used a pipe cleaner on all the holes, applies synthetic bearing grease, cleaned the brake shims and applies anti seize to them, put it all back together. Was fine for a few weeks, now after my car was sitting for 6 weeks, I went for a drive and it was seizing up. I had to replace the master and bleed the brakes, they work fine, but sometimes that pad drags.
When I say it is seizing, I mean it does not slide open very well, it actuates just fine, I can compress the piston back in and it locks up the wheel, just does not release well, hence me asking if there is a helper spring back there as well.
Killtodie
Postby toayoztan » Mon Jan 07, 2013 10:16 am
Ah you mean like a v shaped clip that helps spread the pads apart?
I cant remember if there is one back therr either. Sorry.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby underscore » Mon Jan 07, 2013 4:50 pm
The little V shaped spring thingers are only on the front (checked via the parts catalog)
Postby Fox 21 Alpha » Mon Jan 07, 2013 7:29 pm
Most calipers aren't ment to release very far at all, just a few mm usually which can be barely visible depending on how thing your pads and rotors are. Did you compare it to the otherside? Or are you smelling/seeing it heat up or feeling it pull? And cleaning the bolt and the outside won't do anything for the actual piston, you have to actually take out the oil seals and pull out the piston and clean it, you can use extremely fine sand paper to finish it (600/800/1400 progression or something of the like). Rebuild kits are pretty cheap. Little pain in the ass to do to get it back together but not too bad in the scope of things.
Fox 21 Alpha
Postby Killtodie » Mon Jan 07, 2013 7:43 pm
its dragging, smoking, and rubbing. The piston is fine, its the slide bolts that are causing it too stick. If I have the caliper out in my hands, it does not slide smoothly like the rest
I'll take it apart again today and take some pics.
Killtodie
Postby Fox 21 Alpha » Mon Jan 07, 2013 7:47 pm
Ah. You can get new slide bolts as part of a rebuild kit too, assuming its the bolts and there isn't much rust or whatever built up on the bolt holes in the caliper. If that's the case you'd have to get a creative way to clean it out. The only other thing I can think of is its not bolted on right or at angle or something which is pushing the caliper into the bolts at an angle and not letting it slide easier.
Fox 21 Alpha
Postby 88gt4DE » Mon Jan 07, 2013 10:53 pm
I had a similar problem and only on one side after long drives. Did the caliper and it still happened. had new lines on deck to put on already so I did them and never had a problem again. Bad rubber brake hoses can act as a one way check valve and release pressure very slowly. Another maybe for ya to look at ...
Postby Killtodie » Wed Jan 09, 2013 5:49 am
So I re-greased the slide pins, dont hear or smell them anymore.
The pads were cooked, had to rub them against each other for a few minutes to get all the dust off, flaking and pitting. Cheap pads, so I dont care. Getting some hawk pads and blank brembos in the future, as long as they dont stick again.
Killtodie
Postby Killtodie » Tue Jan 15, 2013 6:33 pm
Well, its been a week. I dont smell or hear them anymore, and no more brake dust. Think my issue has been resolved. I should probably rebuild them though when I get new rotors and pads
Killtodie
Postby Killtodie » Wed Jan 16, 2013 4:21 am
Ugh, spoke too soon. Started making noise on the way back home today and they deff smell of burned calipers
Killtodie
Postby Killtodie » Mon Jan 28, 2013 6:38 pm
ok, brake caliper totally seized up, could not get it to retract. Bought a new one locally for $55, works great. Much better braking and pedal response. Now I have to keep things even and buy a new rotor for the other side. Its probably on its way out too, judging by the rotor wear pattern.
Killtodie
Postby gearhead313 » Wed Jan 30, 2013 3:11 am
bet the flex line is going bad....
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby Killtodie » Thu Jan 31, 2013 8:15 pm
gearhead313 wrote:bet the flex line is going bad....
I'm getting stainless when I can. Replaced both rear rotors, big improvement. The second one was on its way out as well.
Killtodie
