ST165 Struts and Rotors
Postby JohnNK » Thu Jan 10, 2013 6:56 pm
I need to replace the rear rotors and all struts on my ST165. I have a modest budget. Any recommendations or advice is greatly appreciated.
JohnNK
Re: ST165 Struts and Rotors
Postby Killtodie » Thu Jan 10, 2013 7:29 pm
Front struts are easy to replace, you can get them from Rock Auto. I recently purchased a pair of these: MONROE Part # 73238.
Rear's require cutting and welding to get an insert in there, they are sealed and I don't believe anyone sells the entire strut assembly.
Rotors, you can get whatever fits your budge from Rockauto.com or spend a bit more and get some Brembo blanks and hawk pads.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Postby UtahSleeper » Thu Jan 10, 2013 8:12 pm
80 Corolla Hatchback - Power (In Progress) http://www.3tcgarage.com/viewtopic.php?f=23&t=3208
88 Alltrac - Snow (Waiting for the garage) http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=43482
Cardomain - http://www.cardomain.com/id/chris52580
UtahSleeper
Postby Killtodie » Thu Jan 10, 2013 8:44 pm
are those ebay rear struts actually fit? I was told Monroe did not have rear struts available for teh all trac
Killtodie
Postby klue » Thu Jan 10, 2013 9:46 pm
There is a difference between the shock and strut replacement.
I dont know any company that makes a full strut for the rear, they almost all require some good cutting, and a collar welded on.
Go with something nice like a koni or kyb AGX you wont regret it
Postby Killtodie » Fri Jan 11, 2013 4:43 pm
btw, Monroe confirms that those struts linked higher up on eBay DO NOT WORK on the AllTrac.
Killtodie
Postby UtahSleeper » Fri Jan 11, 2013 5:56 pm
My bad. I just did a quick search and found those. Are the rear struts on our tracs really that different?
UtahSleeper
Postby Killtodie » Fri Jan 11, 2013 7:30 pm
UtahSleeper wrote:My bad. I just did a quick search and found those. Are the rear struts on our tracs really that different?
I would like to know the difference too cause they look pretty damn close to be the same.
Killtodie
