St 165 springs
St 165 springs
Postby Tacticalgt4 » Sat Jan 12, 2013 5:19 pm
I just fixed up my all trac and started driving it around. While fixing it i found that the previous owner's lowering technique was to cut down the springs, a lot i think it is about 2 inches lower. I am trying to do a more street friendly set up. Are there any good spring kits that anyone can recommend?
Tacticalgt4
Re: St 165 springs
Postby ZeroDrift » Sun Jan 13, 2013 3:58 pm
I don't know what spring options are left for the ST165 at this point in time. Have you considered the Ground Control spring setup and threaded shock perch?
Re: St 165 springs
Postby klue » Sun Jan 13, 2013 4:44 pm
The only ones I can get now are the bg suspension ones at 1.6" drop.
Pretty sure all the others are discontinued :(
Re: St 165 springs
Postby Tacticalgt4 » Thu Jan 17, 2013 1:05 am
Thanks for the advice. My other thought is to go back to stock so i dont have to do much tuning to the suspension.
Tacticalgt4
