suspension options
suspension options
Postby xander279 » Wed Jan 16, 2013 12:49 am
Right now my current suspension is shot. it needs to shocks, struts, springs, as well as mounts. where can i find all these parts?
If the price is too high i'm considering getting either the Megan Racing street coilovers or the KSport Kontrol Pro coilovers.
2013 Hyundai Genesis Coupe 2.0T
1992 Toyota Celica All-Trac Turbo
xander279
Re: suspension options
Postby lumbercis » Wed Jan 16, 2013 4:38 am
You sure you need springs? Doesn't seem like they're really something that goes bad. :shrug:
I'd recommend just getting OEM rears and Koni inserts for the front. If you need front top mounts go OEM as well. I ordered KYBs once and they were obviously not as well-made as OEM.
I use Curt at Elmhurst Toyota for OEM parts.
Caldina powered...
lumbercis
Postby brutekiller787 » Wed Jan 16, 2013 4:24 pm
you might as well get coilovers as the rear setup is hard to find. go with ceika coilovers, apparently i've had them for a while just didn't know the brand and i love them. custom setup and spring rates for less than 1000
brutekiller787
