Ichiba vs H&R?
Ichiba vs H&R?
Postby toayoztan » Wed Feb 20, 2013 5:36 pm
So I'm looking for either 20 or 25mm wheel spacers in the rear.
I'll be running 17x9 35+ with 255/40.
I have brand new stock OEM wheel studs.
There's two brands, Ichiba and H&R that seem to be reputable.
On either of those, it seems I would need to run the setup that bolt to the stock hub and has its own studs pressed into the spacer.
Several questions:
1) Overall, which do you recommend, ichiba or h&r?
2) Should I even consider running this style stud, or should I put in extended ARP studs?
3) If ARP extended studs, what's the part # you've found to work?
4) To confirm, our center bore is 54.1?
Honestly, I don't want to pull the knuckle/hub apart all over again just to put in extended ARP wheel studs, unless i'm convincned it's absolutely necessary/safer to do because the other setup is a "for-sure" crap deal. I didn't think I'd be needing or using them so I went with OEM new studs.
I hear about Ichiba studs being of sub-optimal quality with complaints of them breaking or what not. Not sure if people aren't running hub ring, etc to help reduce load on the studs. I haven't really heard much about the H&R studs being poor quality yet (DRM style).
What do you guys think?
Will be running upwards of 500+hp.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: Ichiba vs H&R?
Postby Punknoodle » Wed Feb 20, 2013 7:25 pm
I'm personally using the H&R spacers and found them to be fantastic quality.
Punknoodle
Re: Ichiba vs H&R?
Postby CMS-GT4 » Wed Feb 20, 2013 7:47 pm
I ran h&r spacers on the rear for several years with no problems. Some of what I read on spacers is pressed style is preferred over 15-20mm. I would run 25mm in the rear. The rear fenders flare a bit more than the fronts so you will have a little bit more space to fill, plus it gives you guaranteed clearance of any struts. I have the exact setup you are doing (38et instead of 35) and even with I can go another 10+mm in the rear.
Re: Ichiba vs H&R?
Postby kn0wledge185 » Wed Feb 20, 2013 8:47 pm
+1 cms-gt4 I'm currently running h&r 25mm in the rear...... and no problems at all
kn0wledge185
Re: Ichiba vs H&R?
Postby toayoztan » Thu Feb 21, 2013 1:48 am
But you guys aren't running extended studs, correct?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: Ichiba vs H&R?
Postby klue » Thu Feb 21, 2013 2:24 am
I use bolt on and the extended studs on the race car. HR is good stuff and a company I deal with.
54.1 is correct
Re: Ichiba vs H&R?
Postby toayoztan » Thu Feb 21, 2013 2:55 am
Alright, H&R 25mm DRM it is, thanks guys!
Seems like you can't find them cheaper than 150 bucks-ish...spending money on this car never ends!
Searching by the part number provided by H&R's website, I see autoplicity has them for the cheapest...too good to be true? I've never heard or dealt with them.
https://www.google.com/search?q=5025541 ... 20&bih=912
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: Ichiba vs H&R?
Postby klue » Thu Feb 21, 2013 10:44 pm
You can also purchase from me (xiiimotorsports) authorized alltrac.net vendor. You will be sure to get the best price and support a forum vendor is always nice :)
Send me the part number you like and I will price it for you
Luke
Re: Ichiba vs H&R?
Postby toayoztan » Thu Feb 21, 2013 10:55 pm
Yeah I didn't think about going through our own vendors (brain fart).
According to H&R, part # is 5025541.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
