Pricey spherical bushing alternative?
Re: Pricey spherical bushing alternative?
Postby mx6er2587 » Mon Jul 06, 2015 1:51 pm
are the new z products actual spherical bearings? Pictures?
mx6er2587
Postby MWP » Mon Jul 06, 2015 1:57 pm
The TAB-002Z looks like this.
Its a sealed spherical bearing, just like the original Toyota bearing.
Postby mx6er2587 » Mon Jul 06, 2015 4:41 pm
wow that's awesome news. I think I'll be ordering a set today!
mx6er2587
Postby MWP » Mon Jul 06, 2015 5:01 pm
Wait a couple of days :)
I'll report back after ive installed them.
Postby MWP » Wed Jul 08, 2015 12:29 pm
I installed one this arvo, looks like they will work great.
Postby ___Scott___ » Wed Jul 08, 2015 5:01 pm
That's a good find, thanks for verifying that they are a viable alternative for the OEM bearings. I guess now I'll have to update my webpage here to include this new info.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby MWP » Wed Jul 08, 2015 5:12 pm
Well they fit and look ok.
Who knows how long they will actually last as yet.
They do have a 60,000km warranty though if that means anything.
Postby mx6er2587 » Wed Jul 08, 2015 6:27 pm
well there will be two of us to guinea pig. Mine are on their way. Not sure how soon I'll get them on the car though.
mx6er2587
Postby 88gt4DE » Sun Jul 19, 2015 5:49 pm
MWP wrote:How did they not work out?
They were too big and they wouldn't press in. OEM went right in. :shrug: Now that I see the pictures of yours , the ones i got didnt look like those. They looked more like the ones in the first couple pictures of the post ...
Postby ___Scott___ » Sat Jun 11, 2016 3:33 am
MWP wrote:Holographic stickers on the bearing boxes to prove they are genuine and made in Germany.
They must have had problems with chinese rip offs in the past.
To answer the question of whether they are made in China or not, here is a photo of the stickers on the boxes I got:
A nice hologram (probably also made in China) and an actual "Made in China" sticker.
I will also note that they are 0.005" bigger diameter than the OEM bearings and that small difference in size makes a big difference in the difficulty of installing them. I resorted to opening up the rings on the hub a little with a 60-grit cartridge roll and a die grinder in order to get them to go in. Having done that, they should be easy to replace next time if they don't last very long but going back to OEM bearings will require some trickery to shrink the rings.
Scott
SONY
___Scott___
Postby MWP » Sat Jun 11, 2016 4:04 am
Hrm, cant say im a fan of resizing the ring like that.
Its very very easy to go too far, and end up with the bearing not being tight enough... then you need a new hub.
I did it without having to resize the bearing housing ring. It wasn't easy, but it worked, and its the way i would do it again.
First i took the end rubber seals off the new bearings.
I then put the bearings in the freezer, and heated the ring with a blow torch to expand its size a little.
Then i pressed in the new bearings using a 2-arm bearing puller pressing a large socket on the bearing (using the socket meant i was pressing on the outer case of the bearing, not on the centre bearing which would damage it).
Once pressed in, i packed in a little more grease then put the rubber seals back on. Done.
Taking the hubs off and doing it with a proper hydraulic press may end up being easier... would certainly curse at it less anyway.
Postby ___Scott___ » Sat Jun 11, 2016 4:34 am
MWP wrote:Hrm, cant say im a fan of resizing the ring like that.
I can't say that I disagree, just that it's the way I did it. It is possible to shrink the ring without needing to replace the hub, but that's also something easily screwed up so I won't give anyone any crazy ideas.
Scott
SONY
___Scott___
Postby Mad Mike » Mon Nov 14, 2016 5:49 pm
How are these aftermarket bushings working after a few months? Can't decide on OEM or these. Price difference is huge!
Mad Mike
1986 Toyota Corolla
Postby MWP » Tue Nov 15, 2016 4:49 am
All good so far.
Postby ___Scott___ » Tue Nov 15, 2016 10:11 pm
I've only put about 2K miles on mine so far, but so far so good.
Scott
SONY
___Scott___
