Steering wheel spins freely!
Postby Synchrite » Mon Jun 17, 2013 11:53 pm
When I look from the top near the firewall I can see where it's broken...
On this diagram, is this that part? Is there a good way to get to it, or should a newbie get it to a shop for this repair? Thanks!
Edit: had a diagram pointing to the wrong part :/
Synchrite
Re: Steering wheel spins freely!
Postby 187flatliner » Tue Jun 18, 2013 12:02 am
actually not that hard, just time consuming, at least four hours of work. i have an entire steering assembly for a st165 available you didnt say what model and year it is.
GOT PROBLEMS WITH MY FWD
187flatliner
Postby Synchrite » Tue Jun 18, 2013 12:28 am
It's an st185, thanks for the input!
Synchrite
Postby tubasteve » Tue Jun 18, 2013 8:06 pm
Didn't take hours, maybe an hour. Remove the bolts completely, soak in wd40 or the same lube, push up, pull down you're out. Remembering the orientation the coupler was. Install in reverse.
tubasteve
Postby sinerasis » Tue Jun 18, 2013 9:25 pm
Go Cougs.
Jeff
1989 ST165 Black
sinerasis
Postby Synchrite » Tue Jun 18, 2013 11:07 pm
sinerasis wrote:Go Cougs.
Haha. Yes.
Got it out, but the shaft above it is loose and wiggly.... guess its further up than that u joint! How the heck do you GET to that? Can't seem to find all the bolts holding the steering column boot on..
Synchrite
Postby 88gt4DE » Wed Jun 19, 2013 2:21 am
North of that you are pulling the steering column out ...
