Electric power steering conversion... this will be fun :)
Postby MWP » Mon Jul 01, 2013 11:51 am
So ive decided im going to have a go at this :twisted:
I know other guys have done it into Corollas and Starlets, so why not a GT4?
The other guys have used the EPS unit from a Toyota Yaris (non-ABS), as its the easiest to fit, but they have had issues with the motor overheating.
The Yaris non-ABS unit is fairly easy to use as the EPS control module takes a simple wheel speed sensor input to adjust steering assistance.
This is what a Corolla Alltrac using a Yaris EPS unit conversion looks like:
I'm planning to use a ZRE152 Corolla EPS unit because it has a larger motor that should be more suitable for the heavier steering on a GT4.
The only problem with the ZRE152 EPS is the control module doesn't have a simple wheel speed sensor input, it takes its input via the CAN bus from the engine & ABS ECUs.
Im, hoping that ill be able to program the microcontroller on one of these http://www.crystalfontz.com/product/CFA735YYKKR to take a gearbox speed sensor input, and output packets on the CAN bus that the EPS control module will understand.
By sending the EPS control module variable speeds, ill also be able to modify the level of assistance. So in "race mode" i can have very little assistance, or in "street mode", have high levels of assistance :)
Quite a large project, but i think it'll be worth it.
Now for my first question... does anyone know of a manual steering rack that will fit in place of the normal hydraulic power steering rack?
Re: Electric power steering conversion... this will be fun :
Postby Tecker185 » Mon Jul 01, 2013 12:06 pm
I'm also doing this project, but I'm using a different pump. Check out the 2000-2005 ish mr2 spyder. They use an electric pump but its still hydrolic. Just need power, ground, key on power and speed signal. The ecu in built into the pump so its a petty simple install. Here's a picture of my pump got it for $250 shipped.
Here is a quick and dirty install guide
I plan on doing a write up when I get this thing installed.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 GTS Swapped
02 Tacoma TRD Supercharged
15 Corolla S
86 Toyota 1 ton Dually
Tecker185
Postby rallygarage » Mon Jul 01, 2013 12:14 pm
My big dream.
http://easysteer.co.uk/ is the kit I was planning to use. You first have to convert GT4 to a non hydraulic rack this is hopefully faster than OEM. I am using an electric hydraulic pump now. This is in my rally car. Very noisy.
rallygarage
Postby MWP » Mon Jul 01, 2013 12:14 pm
Yeah, quite a few people have done the MR2 pump conversion.
Not much different to the original setup other than you have no pump on the engine.
With the full electric power steering you have no hydraulics at all :)
Postby Tecker185 » Mon Jul 01, 2013 12:16 pm
Word, well I look forward to seeing this completed.
89 ST165
89 SV25
86 AE86 GTS Swapped
15 Corolla S
Tecker185
Postby MWP » Mon Jul 01, 2013 12:17 pm
rallygarage wrote:My big dream.
You're very game to use EPS on a rally car.
Have other people done it?
I cant imagine it holding up to the shock inputs & stresses of rally very well?
The ZRE152 EPS module ill hopefully be getting will be coming from a car that's being built for gravel rally.
It'll be getting a normal hydraulic power steering setup instead.
Postby rallygarage » Mon Jul 01, 2013 12:55 pm
There is many GrF rally cars in Finland with Electric Power Steering. Also many non historic Mk2 Escorts run that.
rallygarage
Postby MWP » Mon Jul 01, 2013 12:59 pm
Well thats good to hear.
So what EPS modules do they use?
The guys that built & run these S2000 Corolla rally cars went back to hydraulic.
http://www.tarmac-mag.com.au/content_fi ... 6Bates.jpg
Postby rallygarage » Mon Jul 01, 2013 7:00 pm
Correct me if I am wrong but dont some current spec WRC cars have EPS?
rallygarage
Postby MWP » Tue Jul 02, 2013 2:12 am
Good question, will do some research.
Even if they do though, i bet its not some EPS unit pulled from a Corolla or similar :P
I would hate to see what a WRC level EPS system would be worth!
Postby MWP » Tue Jul 02, 2013 6:31 am
And there goes the power steering gear... now im committed :doh:
Postby bmt » Tue Jul 02, 2013 7:31 am
This does sound interesting! What are the pros and cons of electric power steering?
Obviously power gain to the wheels as the motor isn't driving the power steering pump.
On the con side is the lack of feel associated with some units.
Good luck i will be watching
bmt
Postby MWP » Tue Jul 02, 2013 8:50 am
There will be a very small power gain due to the removed PS pump idling losses.
Of course when the electric PS is in use, there will be extra draw on the alternator.
Lack of feel ill be able to tune out hopefully.
Postby MWP » Mon Jul 22, 2013 11:41 am
For anyone thats interested, this is what the input shaft & pinion look like in 185 steering racks.
Im manualising the steering rack, so the torsion rod in this shaft needs to be locked up.
Postby DeeCee » Mon Jul 22, 2013 7:16 pm
Did you consider using a PS unit from a SW20 MR2? I have seen that conversion used in the past.
I can understand the use of an integrated unit to reduce additional plumbing but will there be enough room under the centre console?
DeeCee
