Electric power steering conversion... this will be fun :)
Re: Electric power steering conversion... this will be fun :
Postby MWP » Tue Jul 23, 2013 2:49 am
Nah, didn't consider the SW20 pump.
I want all the hyd lines gone.
As for room under the dash... ill make room :P
Postby DeeCee » Tue Jul 23, 2013 4:35 am
I thought removing all hard lines might have been the reason.
There is a decent amount of room under there if you don't want a lot of the air conditioning and air vent stuff. I've saved heaps of room ditching the heater unit for a smaller unit
DeeCee
Postby MWP » Tue Jul 23, 2013 5:45 am
Ill be keeping the stock heater unit, but yeah, the crotch vent pipe will probably go.
Postby MWP » Tue Jul 23, 2013 5:48 am
If i cant fit it in with the motor pointing up, it'll end up being like this which will still be ok...
Postby MWP » Tue Jul 23, 2013 6:31 am
So this is what ive done with it so far.
Ill now fill as much of the cavity as i can with jbweld.
Postby DeeCee » Tue Jul 23, 2013 7:00 am
hmm.. reservoir looks like it sits below the dash trim line. Potential leg interference or are you good?
DeeCee
Postby MWP » Tue Jul 23, 2013 7:22 am
Reservoir? You mean the electric motor.
That not my car... thats a photo of someone else who has done it in a Corolla.
It might hang a little below the dash trim like that, but i dont think it would get in the way of your legs/feet.
I think the ZRE152 EPS motor isn't as long as that one either.
Postby DeeCee » Tue Jul 23, 2013 7:05 pm
oh.. its an electric motor. And I didn't think you had a st165. Sorry for confusion.
DeeCee
Postby MWP » Wed Jul 24, 2013 3:57 am
Postby DeeCee » Wed Jul 24, 2013 4:04 am
Yes, your signature says and I have read through your project before. Hence the confusion with the LHD older vehicle.
So when do expect to have everything completed?
DeeCee
Postby MWP » Wed Jul 24, 2013 4:17 am
Ahhh right :twisted:
Yeah, those photos are from a guy in the US who has put the Yaris EPS unit into his AE95.
Work log is here: http://www.toymods.org.au/forums/engine ... ering.html
I have no idea when it'll all be done.
Even though im manualizing my steering rack now, i might not have the EPS unit installed under the dash for some time. If i need to drive the car before i get the EPS unit installed, it just wont have any power assisted steering.
A friend of mine is currently stripping down a ZRE152 for rally use, so probably wont be using the EPS column it has. Ill wait until he is happy to hand it over.
Postby MWP » Mon Aug 05, 2013 3:50 am
Progress...
Rebuilt & manualised ST185 rack.
Postby bajallama » Wed Nov 12, 2014 9:58 pm
So here is my documentation of the same conversion on my 165. I ran an 08 Scion XD column and used an ABS computer, just wired it up.
http://www.projectz61.com/vehicles/st165-all-trac/toyota-electric-power-steering-conversion/
ProjectZ61.com
bajallama
Postby MWP » Thu Nov 13, 2014 1:43 am
Nice :)
So is your blog up to date? Its still running in limp-home mode so far?
Megasquirt can't output CAN bus packets suitable to run the EPS without specific support being added to the MS firmware.
Its been a while since i update this thread... mine is all up and running & on the road.
Test fit:
Just fits:
Original column mount:
New column mount:
Column fitted up and working.
EPS control box is mounted where the factory ECU normal sat.
Postby aus jd 2703 » Thu Nov 13, 2014 3:13 am
what's the feel like MWP?
worth the time and effort?
aus jd 2703
