st205 rear knuckle
st205 rear knuckle
Postby warracer » Tue Jul 30, 2013 11:04 pm
Hi, really quick question,
I need to know if the rear knuckle for the st205 is the same as the st185?
My st185 rear right knuckle cracked due to some unknown reason and all the knuckles I can find are from a st205...
Thanks!
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Re: st205 rear knuckle
Postby CMS-GT4 » Tue Jul 30, 2013 11:42 pm
The center bore is slightly larger than the 185, so I doubt your 185 rotors will fit.
Postby warracer » Wed Jul 31, 2013 12:28 am
ah , thanks! :D
valuable information here!
____________
ST185H A-Spec:
warracer
Postby phattyduck » Wed Jul 31, 2013 3:41 pm
Part numbers between the ST205 rear hub carrier and the the earlier cars (ST165/ST185/SV25) are different, but you can probably use one (or maybe a pair) after swapping out your hubs into the carriers. The wheel bearings are the same for all of those hubs (ST165/ST185/ST205/SV25). I used my stock Camry Alltrac rear hubs when I did the swap to the rest of the ST205 suspension parts (subframe, diff, arms, axles, brakes) and it worked out fine. I am keeping the ST205 hub/knuckle assemblies as spares for later though...
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
