Whiteline quick release bolts
Postby CMS-GT4 » Mon Aug 12, 2013 5:37 pm
Anyone use these? I was going to pick up a set to make life easier unless there is a cheaper way to make a set.
http://www.whiteline.com.au/product_det ... ber=ksb790
Re: Whiteline quick release bolts
Postby underscore » Mon Aug 12, 2013 6:01 pm
Not a bad price, I've been wanting to do something similar.
Postby CMS-GT4 » Mon Aug 12, 2013 6:07 pm
I was pricing the parts at mcmaster and it seems each bolt would be $12 anyway. So this is looking like a better price already. I will get a set for the front, but I might consider a set for the rear if I never need to haul anything.
Postby phattyduck » Mon Aug 12, 2013 7:47 pm
I have those on the rear strut tower brace of my WRX wagon. Very helpful for when I need to carry bigger/more stuff inside the car. I don't think I'd put one on the front brace though - If I'm in there working, I already have tools out.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby klue » Mon Aug 12, 2013 8:41 pm
phattyduck wrote:I have those on the rear strut tower brace of my WRX wagon. Very helpful for when I need to carry bigger/more stuff inside the car. I don't think I'd put one on the front brace though - If I'm in there working, I already have tools out.
ditto
Postby MARLON1211 » Sun Sep 22, 2013 12:43 am
Yes I know sometimes its hard to put oil when the bars are in the way. Well i can always use a funnel.
Here's mine.
SO BE IT
MARLON1211
Postby CMS-GT4 » Sun Sep 22, 2013 12:55 am
I am going to put mine on front as well. Turns out if I want them on the rear, I have to cut more plastic.
Postby underscore » Sun Sep 22, 2013 1:55 am
In that case probably easier to buy a couple cheap wrenches and just keep them in the glovebox/spare tire well.
Postby phattyduck » Mon Sep 23, 2013 6:19 pm
MARLON1211 wrote:Yes I know sometimes its hard to put oil when the bars are in the way. Well i can always use a funnel.
Here's mine.
I use the top of a bottle cut off as my oil funnel. It just about screws into the oil cap opening on all my cars, and I used it on all of them (Subaru, Mini, 3s-gte Camry...). It just fits under the strut bar on the Camry and is just enough to get be able to reliably pour and not spill. In an emergency (road trip and low on oil), I am just careful and use a couple paper towels to protect the engine from spills.
phattyduck
Postby Insanity-74 » Tue Sep 24, 2013 5:46 am
They look like bike seat post quick release clamps. You can buy them for a couple of £ off eBay.
Here's an example
http://www.ebay.co.uk/itm/150435318215? ... 80&ff14=54
Just cut them down to size if needed.
Your local bike shop will probably sell them for not a lot of money, certainly cheaper than the white line price.
Insanity-74
Postby CMS-GT4 » Tue Sep 24, 2013 2:21 pm
The problem with the bike bolts is their diameter is much smaller than the whiteline bolt. My whiteline bolts have almost no wiggle room, and I assume its because they act as part of the structural rigidity of the strut bar. I don't think friction alone on the side would hold it tight as it would have to compress the sides of the bracket against the bar to prevent any movement. I don't think the materials have enough give in them for that.
Postby 1337computing » Tue Sep 24, 2013 2:54 pm
Is that a FCD you have mounted there?
Here's mine.
1990 Celica All-Trac Turbo ST185
3" Berk DP, 3" Straight Piped, Magnecor Wires, EBC+
1337computing
Postby phattyduck » Tue Sep 24, 2013 3:52 pm
Insanity-74 wrote:They look like bike seat post quick release clamps. You can buy them for a couple of £ off eBay.
Here's an example
The auction you listed is for the M6 version. They have an M8 that *might* work. The Whiteline bolts are more like M10. The bike parts wouldn't measure up for total strength, but it may or may not be needed.
I am seriously considering bike seat post quick releases for other projects though... :wink:
phattyduck
Postby warracer » Tue Sep 24, 2013 7:30 pm
wow thats cool , never thought of that, Ill make some at school :)
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
