Rally style suspension for my st165?
Postby chevyok06 » Fri Nov 08, 2013 5:09 am
I'm looking for a new suspension for my st165. It has drop springs on it now and is just to low for me and o really want to put the awd to good use and be able to sue it well on windy back roads and tracks and such. Any one know where I can find a full bolt on set of maybe coil overs etc etc. Also wondering what size tires rims brands etc I should run. THANKS.
:withstupid:
chevyok06
Re: Rally style suspension for my st165?
Postby klue » Sat Nov 09, 2013 12:08 am
If you convert to st185 set up, I have something for you
Postby chevyok06 » Sat Nov 09, 2013 12:18 am
You mean from my st165 as a whole?
chevyok06
Postby klue » Sat Nov 09, 2013 3:20 pm
just the front knuckle, the spacing on the holes are different where the bottom mount of the shock meets the knuckle
Postby gtfourcs » Sat Nov 09, 2013 3:29 pm
what do you have? Just basic coilovers or some that are for offroad (gravel, unpaved roads, and such)? Brand?
gtfourcs
Postby Bryon » Sat Nov 09, 2013 6:23 pm
I just recently did some back yard shinanigans to my 65 stock struts, but Im not sure you have access to a welder, spring compressors etc etc. Long story short I used KYB agx adjust strut inserts with the bottom nub cut off,front and rear part #765015 repositioned the spring perches up the strut leg about 2 inches, and converted the rear to take a strut insert. the agx strut has about an inch longer stoke then the stock strut so the additional inch just adds to the spring preload a bit. There is a much more detailed article in here regarding the AGX strut swap. I am happy with mine. I have ran 2 Rally x events and they have held up great, I even drove the car off an 8 inch sidewalk at 30mph to see if it would bottom out, and she took it like a champ. Not quite bolt on but only cost me 390. and some labor for four way adjustables and a 2 inch lift.
Bryon
Postby chevyok06 » Sat Nov 09, 2013 9:15 pm
I would be happy with a close to stock set up that's a little more responsive. My drop Springs look good and corner good on pavement but no-good for anything needing clearance lol.
chevyok06
Users browsing this forum: Google [Bot] and 3 guests
