St165 awd suspension question?
Postby chevyok06 » Mon Nov 11, 2013 6:43 pm
Just bought an 88 awd turbo Celica. Super happy with it but it's really low right now. To pass safety I need it back to stock or close. My question is, is the awd suspension the same as say a 88gt? If not any one got any recommendations on good suspension that won't cost an arm and a leg.
chevyok06
Re: St165 awd suspension question?
Postby sinerasis » Mon Nov 11, 2013 7:36 pm
Not the same. Although I think GT-S suspension will get you past an inspection, it's just not designed for the extra weight so it's probably not a good long term solution.
How is the car lowered? Maybe you're lucky and it's adjustable?
Jeff
1989 ST165 Black
sinerasis
Postby chevyok06 » Mon Nov 11, 2013 7:40 pm
Pretty sure there just drop Springs. I wasnt looking to put the gt suspecting itself on just use the gt as a search parameter online since most websites don't have awd Celica as an option
chevyok06
Postby sinerasis » Mon Nov 11, 2013 8:05 pm
Gotcha. Others will chime in I'm sure, but I believe you need GT-S as opposed to GT. I think the GT-S stuff will fit although its not designed for the weight. I don't think the GT stuff will work at all.
Jeff
1989 ST165 Black
sinerasis
Postby Overtriped » Mon Nov 11, 2013 9:49 pm
I wouldn't bother with Any other system than what is made for an Alltrac, It would be a waste of time and money, im sure you would regret it.
Im going though the same thing right now.
I sourced Used parts.
KYB offers struts, and there are many many different manufactures of springs, stock, drop, or lift.
Koni also sells struts, so does NAPA.
KYB is by far the cheapest option.
Id start searching on the for sale section for a 165 or 185 part out, either system will work. The 185 stuff needs to be modified to work, but will actually set higher than stock and it is beefier.
I also have a 185, and im ordering a set of the BR series coilovers, I think eventually my 185 stuff will get transferred onto the 165.
Or just register your car as an antique and don't worry about inspections. :) good luck !!
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Postby chevyok06 » Tue Nov 12, 2013 3:07 am
Any good websites I can order a full suspension from?
chevyok06
Postby 187flatliner » Tue Nov 12, 2013 4:54 am
you can also search for any thing for the st185 as well, it will all bolt in with an st165
GOT PROBLEMS WITH MY FWD
187flatliner
Postby chevyok06 » Tue Nov 12, 2013 5:01 am
Really? I heard they take some modifications to fit
chevyok06
Postby underscore » Tue Nov 12, 2013 5:18 am
I think the 165/185 rears are the same, but the fronts are different. The fronts should be the same between the 165 and 162 though, so a hodge podge of parts might be able to work.
Postby alltrac7935 » Wed Nov 13, 2013 2:16 am
are you looking for struts or shocks for your st165?
i ordered B and G online from IRP B&G S2 Sport Springs (92.1.016)
Then i ordered front kyb stock oem replacment from THmotorsports KYB GR-2 / Excel-G Gas Shocks (365064)
Then the matching KYB rear struts from http://www.fensport.co.uk/
im doing this right now.. i was wondering do I need to buy new bushings or new boots or anything eles to fit this suspension? This is my first time installing suspension on any car.
alltrac7935
Postby chevyok06 » Wed Nov 13, 2013 3:51 am
I'm looking for some one that makes a bolt on Coil over set
chevyok06
Postby ___Scott___ » Thu Nov 14, 2013 12:31 am
I can't help with an off-the-shelf solution, but here is a link that I haven't seen posted in a decade or so:
http://www.y8s.com/celica_gone/suspension.html
By cutting the tops from an old set of front struts and welding them to the tops of the rear struts, you can use inserts in the rear, just like the front.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
