Which is the most affordable big brake kit for ST185?
Postby gt4tified » Mon Nov 18, 2013 4:55 pm
As the topic says, I am investigating my option of purchasing a big brake kit for my ST185. I was looking towards the ST205 conversion but it sounds like there may be a lot of work...if it does not cost an arm and a leg more, I would prefer something bolt-on ready off the shelf.
Any suggestions as to the most affordable BBK?
gt4tified
Images: 5
Re: Which is the most affordable big brake kit for ST185?
Postby CMS-GT4 » Mon Nov 18, 2013 5:09 pm
I'd say its between the revolution (ebay) kit and the Porsche brembo kit.
Postby underscore » Mon Nov 18, 2013 5:29 pm
^ Agreed. IIRC the benefit of the Revolution kit is you get all brand new parts, but the Porsche kit lets you use over the counter parts from other brands (easier to source spares).
Postby gt4tified » Sun Nov 24, 2013 2:48 am
Thanks for the response guys. Would the porsche kit clear 16" rims? I know the revolution won't but if the porsche clears my rims then that's a wonderful reason to go with that option.
gt4tified
Images: 5
Postby underscore » Sun Nov 24, 2013 4:37 am
AFAIK it's 17" only, and even then some of them can be a very close fit (my RPF1's clear by maybe 1mm)
Postby NSergei » Sun Jun 14, 2015 11:39 am
Fullsize 205 brakes (315mm) for 185
NSergei
Postby GT4times2 » Sat May 21, 2016 5:59 am
NSergei,
What did you have to do to make these fit the fronts for the ST185? I have ST205 front and rear brakes and want to install them on my ST185. Elaborate if you can.
Thanks.
Frantz
12 Toyota Sienna LE (The Daily Pacifier)
05 Toyota Avalon XLS
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby FC Zach » Sat May 21, 2016 7:50 am
GT4times2 wrote:NSergei, Elaborate if you can.
This is the problem I ran into when researching what and how others made their 205 calipers work for the front. . . They either can't or wont disclose any information like it's some highly guarded secret! With that being said, there was one who wouldn't because it would cut into their profits if their little secret was out (they were selling bolt-on kits).
My guess is those are STI rotors in the above pic but my follow-up question would be, Is there any need for a spacer between the hub and rotor?
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby NSergei » Sat May 21, 2016 11:58 am
Thanks.
Rotors are st205, with spacer 8,5 mm. and centring ring,
Front calipers has been modified.
Can send photo via email.
specify what you wont to see.
NSergei
Postby GT4times2 » Sat May 21, 2016 2:18 pm
Thanks.
Thank you Sergei. I will send you a PM, with my email address. I have the hubs, rotors everything complete.
Frantz
90 ST185 Gen4
GT4times2
Postby GT4times2 » Sat May 21, 2016 2:27 pm
Sad they won't share how they did it. We're a small group. There's the STi rotors/Porsche caliper route.
Someone had the Lexus LS430 calipers(+adapter), with STi rotors set up. I tried to contact him for a kit. Never heard from him. I've had these ST205 parts laying around, so why not make them work (or at least try to) on the ST185.
Frantz
90 ST185 Gen4
GT4times2
Postby All-TracDreams » Sun May 22, 2016 1:54 am
Agreed, sir. I'd be willing to pay for a bracket or some other solution which allows bolt-on fitment of ST205 front calipers and rotors just like the rears.
All-TracDreams
Postby CSAlltrac » Mon May 23, 2016 1:22 am
This is the most cost effective way of mounting the 205 brakes.........
viewtopic.php?t=50455
Unlike some of the pieces of work on the board, Redswan made a very clear post on how to get it done, and when he is not busy does reply with informative help. There's a bunch of different ways to go about it and every single one is different. Some people will also disagree with some of the methods used. Beyond the 205 brakes, the Porsche option is the most affordable.
Postby FC Zach » Mon May 23, 2016 1:50 am
CSAlltrac wrote:This is the most cost effective way of mounting the 205 brakes.........
Unlike some of the pieces of work on the board, Redswan made a very clear post on how to get it done, and when he is not busy does rely with informative help. There's a bunch of different ways to go about it and every single one is different. Some people will also disagree with some of the methods used. Beyond the 205 brakes, the Porsche option is the most affordable.
I followed Redswan's thread, he was very helpful and even sent me an extra set of centering rings for the rotors. I've been running this set-up for around 5 months now and with no complaints.
FC Zach
Images: 9
Postby FC Zach » Mon May 23, 2016 3:16 am
This reminds me. . . I made a word document with detailed info on my install that I've been sitting on and holding off from sharing till I tested it out and really abused the car. So far so good after ~five months so I made a thread:
viewtopic.php?f=49&t=51510
FC Zach
Images: 9
