Recommended setup Rally ST165
Postby texturboII » Thu Jan 23, 2014 3:45 pm
Hey guys, newbie here.
I'm looking into setups and simply don't know where to start. The shocks and springs currently on the car are Koni's and while they lower everything down nicely, this is going to be a rally car so low is a no-go. Sooooo what do you guys recommend for a good suspension set-up for Rallysport? It would be on dirt and gravel, for now, with minimal air-time considering the tracks we'll be racing on.
I'm completely in the dark as far as suspension goes, I'm more of a Engine/Tuning guy myself. We're refreshing the whole car, so new bushings, bump-stops, etc... Any help is appreciated, thanks for reading!
texturboII
Re: Recommended setup Rally ST165
Postby Eurus » Fri Jan 24, 2014 6:09 am
I just ordered a set from Ceika, built for rally cross, since I can get inverted shocks etc.. It will probably be a few months before I can test them out.
Im sure there will be someone on here that has better info than myself. Id normally recommend the forum special stage, but its more dead than here, and I haven't seen anyone else with an alltrac yet.
Eurus
