Megan Racing Coilovers
Postby AxelNavaja » Tue Feb 04, 2014 4:36 pm
Im looking at a set for my ST184. Has anyone ever used Megan Racing coilovers one their car? I dont really track the car or anything like that just some spirited driving here and there. I mainly like them cause of the range of adjustability. Any feedback on them...? Thoughts?
-1991 ST184 HatchBack
Keeping Her Alive One Part at a Time.
AxelNavaja
Re: Megan Racing Coilovers
Postby Killtodie » Wed Feb 05, 2014 1:33 am
I heard good things about them, they are the cheapest. I was also told that they can be adapted for the All-Trac.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Postby AxelNavaja » Wed Feb 05, 2014 11:39 am
Every set ive seen states that it can be applied for the alltrac, gts, and gt. I just want to see if anyone's ever used them before i go buy them.
AxelNavaja
AxelNavaja
Postby k.beaty » Wed Feb 05, 2014 12:15 pm
I had them on my car for a few year and just made the switch to BC Racing.
I'd recommend the BC's over the Megan's any day! Also, look into the Swift Spring upgrade with the BC's, it makes a world of a difference!
Follow me on Instagram @kbt666
k.beaty
Postby Mafix » Sun Feb 09, 2014 9:33 pm
my chassis is far lighter (2600lbs race weight) and i've had no complaints about the megans st184 kit.
Postby celi_wabbit » Mon Feb 10, 2014 5:02 pm
I've had them for 2 years now and still have no problems so far.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
Postby Droptop93 » Mon Feb 10, 2014 6:05 pm
MR-CDK-TCE90GT is the megan part number for the fwd coilovers.
Droptop93
Postby AxelNavaja » Mon Feb 10, 2014 7:12 pm
Did the fwd coilover kit com with camber plates?
AxelNavaja
Postby Droptop93 » Tue Feb 11, 2014 12:04 am
Yes
Droptop93
Postby 94 MR2 Turbo » Tue Feb 11, 2014 5:07 am
I've had them for 2-3 years so far and no complaints. Just make sure there setup correctly spring preload and height etc and make sure to lock the front collars tight! I had one come lose and over time that axle raised about 35-40mm. Looked weird and throws off alignment!!
Probly my fault for not tighting it.
94 MR2 Turbo
Postby Mafix » Thu Feb 20, 2014 8:55 pm
my rf collar comes loose all the time. seems to do it after violent autocross events (lots of runs or bumpy pavement)
Postby Killtodie » Fri Feb 21, 2014 10:36 pm
Is there a writeup with pictures that shows these working in a all-trac?
Killtodie
Postby underscore » Sat Feb 22, 2014 5:29 pm
The rears are definitely different so I'm not sure if they'll work, either way I wouldn't want to run coilovers for a 184 on the 185 rear end due to the extra weight.
Postby Killtodie » Sun Feb 23, 2014 12:28 am
underscore wrote:The rears are definitely different so I'm not sure if they'll work, either way I wouldn't want to run coilovers for a 184 on the 185 rear end due to the extra weight.
I heard that they can be adjusted to work height wise.
I understand the extra weight, but if you increase the dampeners, you can compensate for it.
Killtodie
Users browsing this forum: Bing [Bot] and 3 guests
