Baller on a Budget BBK (BBBBK)
Re: Baller on a Budget BBK (BBBBK)
Postby MWP » Mon Jan 12, 2015 4:27 pm
All Australian ST185's got a rear rotor of (DBA744):
Vent: Solid
Diameter: 288
Height: 60
Thickness: 10
JDM ST185's had a much smaller rear rotor.
Postby bajallama » Mon Jan 12, 2015 5:18 pm
MWP wrote:All Australian ST185's got a rear rotor of (DBA744):
Vent: Solid
Diameter: 288
Height: 60
Thickness: 10
hmmm, then it may not be much of an improvement for the 185 guys except that you get a slightly bigger piston and vented rotor. 205 is probably the better option for those whose residing country sold them. For the US, rear still exceed $300 with used rotors :(
ProjectZ61.com
bajallama
Postby MWP » Mon Jan 12, 2015 5:41 pm
Next time im on a track ill try to remember to measure rear rotor temperatures.
Our local track (Mallala) is the hardest circuit on brakes in Australia.
I overheat my front pads/rotors (std 185, using DS2500 pads) in 1-2 fast laps :(
Postby bajallama » Mon Mar 02, 2015 4:05 pm
ATTENTION
Alright so I sold the last kit and I'm currently getting quotes for making kits for the 185 guys. I however do not have a 185 and my access to one is somewhat "challenging"? Anyways, I went to the junkyard on Friday in search for a 184 LCA and upright and forgot the necessary tools to pull an axle because I'm an idiot. I have machine shops hounding me for models so this is where I need your guys help.
What clearance are you looking for? If any of you have a STi rotor laying around and some washers, can you test fit and see how much space is required to space the rotor out? I would like some pictures also. I had currently estimated that it needed around .125" of offset. I will be waterjetting a steel plate that sit behind the rotor and have the steel concentric ring tacked on the inside. So this will slip on over your hub/wheel studs before installation of the rotor. The bracket will then be redesigned for the larger .125" step.
ProjectZ61.com
bajallama
Postby MWP » Mon Mar 02, 2015 4:13 pm
Argh, i wish i could help.
Im not in a position to buy calipers or rotors as yet :(
Postby bajallama » Mon Mar 02, 2015 4:22 pm
MWP wrote:Argh, i wish i could help.
Ahh, no worries. Did your buddy get his kit yet? I haven't heard back from him since I shipped it.
ProjectZ61.com
bajallama
Postby underscore » Mon Mar 02, 2015 4:50 pm
I'd push it out a bit more than an 1/8" to have adequate clearance on an STi rotor.
Postby bajallama » Mon Mar 02, 2015 4:59 pm
underscore wrote:I'd push it out a bit more than an 1/8" to have adequate clearance on an STi rotor.
What are you thinking? How much material did you shave off your ball joint?
ProjectZ61.com
bajallama
Postby underscore » Mon Mar 02, 2015 5:10 pm
I've taken a fair bit off already and it still rubs, I'll try to measure once I can get it to stop rubbing.
Postby MWP » Tue Mar 03, 2015 4:30 am
Yup, it arrived yesterday. Thanks.
Postby MWP » Sun Oct 02, 2016 4:55 am
So im finally starting to look at doing this upgrade :twisted:
328mm WRX STI rotors on the ST185... maybe i have smaller ball joints or something??
I have plenty of room.
Postby DeeCee » Sun Oct 02, 2016 7:22 pm
MWP wrote:So im finally starting to look at doing this upgrade :twisted:
And how much room is there under compression? With my rotors, there is around ~1.5mm space between ball joint and rotor.
DeeCee
Postby MWP » Sun Oct 02, 2016 11:37 pm
Lol, I didn't think about that, thanks :twisted:
I have some other parts I need to have water cut, so was going to have some behind rotor spacers made up anyway.
Postby underscore » Mon Oct 03, 2016 8:36 pm
Mine were making contact under compression at nearly full lock, so I'd check that as well.
