top mounts
top mounts
Postby 819_ay » Mon Mar 10, 2014 11:53 pm
hey guys, can anyone tell me if front top mounts for a 89 celica all trac would fit my 90 gt4? My local toyota stealership is getting rid of left over stock and has a set of two front top mounts looking to get rid of cheap and fast, don't really need em,but if i can get a hold of OEM for way under there cost, why not!
here is the part number : 48609-20100
thanks
819_ay
Re: top mounts
Postby jsd » Tue Mar 11, 2014 12:16 am
Part 48609-20100 (SUPPORT SUB-ASSY, FRONT SUSPENSION) was found on the following models:
Date range Model Frames/Options Found in diagram
08/1987-07/1989 TOYOTA CELICA ST16* 48-03: FRONT SPRING & SHOCK ABSORBER
Model Dates: Matching Models: Model Options: Links to diagrams:
10/1987-07/1989 ST165L-BLMVZA TBOAT, USA, LB, 3SGTE, MTM, 5F 48-03
10/1987-07/1989 ST165L-BLMVZK TBO4W, CND, LB, 3SGTE, MTM, 5F 48-03
jsd
Re: top mounts
Postby 819_ay » Tue Mar 11, 2014 12:31 am
thank you but i already searched the part number before posting...my question is will it fit a 1992 jdm gt4 rc? must have not specified
819_ay
Re: top mounts
Postby jsd » Tue Mar 11, 2014 12:39 am
Did you use toyodiy? It's not listing the 92 on the Japanese market either. Hope that helps, otherwise I'm out of ideas.
They may still fit though, I have no idea :shrug:
jsd
Re: top mounts
Postby 819_ay » Tue Mar 11, 2014 1:01 am
toyodiy gives methe jdm RC part number is 48609‑20240 which is not the same, when i search the number i'm looking for, it's gives me for a st16* maybe since it's a jdm and RC it wont have the same PN has the ones here
EDIT: toyodiy gives the same PN for st185 JDM rc and USDM for the top mounts...and USDM/JDM is the one i'm looking to know if it fits:48609-20100...so if not the same pn i'm guessing it won't fit?
Thanks
819_ay
Re: top mounts
Postby underscore » Tue Mar 11, 2014 4:13 am
Front top mounts of what?
edit: Oh the strut top hats. The P/N might not be the same but I know people put 185 coilovers in 165s so the spacing for the top three studs should be the same.
Re: top mounts
Postby 819_ay » Tue Mar 11, 2014 6:56 pm
but would i be able to fit them on the struts from my 92 RC?
819_ay
Re: top mounts
Postby saved_1992 » Wed Mar 12, 2014 11:05 pm
I have put the 185 tops on my old 165 so should work
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Users browsing this forum: Yahoo [Bot] and 2 guests
