ST185 power steering not keeping up
Postby Roundy » Fri Apr 25, 2014 2:25 am
Hi Guys,
Had a bit of an issue in the motorkhana, which i have had before.
Basically get to a slalom, and it seems i get no power assistance through there and the steering becomes amazingly heavy.
It would seem that this sort of problem is not uncommon through a lot of cars, however i have seen nothing to really suggest how to fix it!
Any suggestions would be much appreciated
Cheers
Nathan
Roundy
Re: ST185 power steering not keeping up
Postby quieter » Fri Apr 25, 2014 3:38 am
is it leaking?
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby Roundy » Fri Apr 25, 2014 6:11 am
No.
Also worth noting it has an aftermarket PS cooler, but had the same issue with it totally stock
Roundy
Postby RedCelicaTRD » Mon Apr 28, 2014 6:25 pm
Does it only happen in a slalom or have you noticed it at other times?
Postby ALLensTRAC » Mon Apr 28, 2014 8:01 pm
This sounds like high pressure related vein bypass in the pump. I would rebuild the pump and have a good look inside for anything obvious. If it's only occurring at the limits during a slalom you may have reached it's pressure limit. A quick left to right to left can provide delay in assist. This is why I'm working on electric steering for my car.
Allen
ALLensTRAC
Postby Roundy » Mon Apr 28, 2014 9:24 pm
I have only had it occur in the slalom, never noticed it anywhere else.
Roundy
Postby Mafix » Sun May 04, 2014 9:34 pm
and it's not bump steer?
have you done a suspension check over? i'd imagine it's something else.
Postby MWP » Mon May 05, 2014 1:37 am
Roundy wrote:I have only had it occur in the slalom, never noticed it anywhere else.
After mine first happened at the motorkhana, it also started happening at shopping centres, etc :(
Postby Roundy » Mon May 05, 2014 10:34 am
How would bump steer result in stupendously heavy steering?
Roundy
Postby MWP » Mon May 05, 2014 1:08 pm
It cant... odd suggestion there Mafix.
Postby Mafix » Mon May 05, 2014 5:57 pm
making sure its not a binding issue. I've seen bump steer do some strange shit.
edit: we may be defining bump steer differently. at any rate, before the pump/rack are replaced, the front suspension needs to be checked first.
what fluid are you using in the system?
Postby Roundy » Tue May 06, 2014 8:38 am
Penrite fluid is what i am using
Pretty confident that the suspension is all right.
Roundy
Postby ALLensTRAC » Tue May 06, 2014 10:18 am
Can we have a breakdown of current mods suspension wise? Also when was the last time you opened the PS system? Have you replaced the steering rack? Pump? I know you said you have a cooler but what are the dimensions? Is the fluid thicker or thinner than say Dexron trans fluid?
Allen
ALLensTRAC
Postby Mafix » Tue May 06, 2014 8:36 pm
Roundy wrote:Penrite fluid is what i am using
isn't penrite a brand name for lots of fluids?
and pretty confident should ever be good enough. it's not that hard to check her over.
Postby Roundy » Tue May 06, 2014 9:18 pm
Suspension mods:
BC Racing coil overs adjusted for ~2.5° camber, and rotated strut tops for 1° extra camber
Poly bushes all round
Have not pulled out/replaced the pump or the rack, and they have a lot of kms on them (280k kms)
Fluid is: http://www.penriteoil.com.au/products.p ... oducts=160
The cooler is only a small 7 row cooler
Caveat here: I had the issue with a completely stock power steering setup as well.
The only time i have had the problem is through this tight slalom. No other part of the course showed this issue, or any track days, parking lots anything.
The slalom is straight after a burst to the rev limit in first gear.
Roundy
Users browsing this forum: Google Adsense [Bot] and 2 guests
