Where to buy complete front and rear brake upgrade
Postby gt4lm » Sat Apr 26, 2014 10:41 am
Looking for a front and get caliper and disc upgrade set
Instead of running around chasing bits around the world is there a kit from one supplier that will upgrade the lot?
gt4lm
Re: Where to buy complete front and rear brake upgrade
Postby ALLensTRAC » Sat Apr 26, 2014 12:06 pm
Revolutionbrake.com sells the front. Then get st205 rears. Rocketeer used to sell front and rear kits but they are no longer available.
If you really want to ball out AP racing makes a front kit but it's around 4k$!!!
Allen
ALLensTRAC
Postby gt4lm » Sat Apr 26, 2014 9:15 pm
ALLensTRAC wrote:Revolutionbrake.com sells the front. Then get st205 rears. Rocketeer used to sell front and rear kits but they are no longer available.
Is nuts that there is no set available
gt4lm
Postby gt4lm » Sat Apr 26, 2014 11:37 pm
Ok after a few hours of reading
I'll be using 205 rear set however I noticed that people are cutting up cans to use as a locating ring as the centre bore is larger on the 205 disc
Does any one make a proper locating ring to mount the 205 disc in the 185?
Usinfa cut up can feels a bit scary
I could get one made if possible? :shrug:
gt4lm
Postby ALLensTRAC » Sat Apr 26, 2014 11:45 pm
It would be difficult to get machined as it's 0.9mm difference. The best solution is either a complete ST205 rear subframe(this also increases track width by 25-30mm eliminating the need for spacers) or using just 205 wheel hubs. 185 hub is 54.1 and the 205 is 55mm.
Allen
ALLensTRAC
Postby gt4lm » Sat Apr 26, 2014 11:55 pm
ALLensTRAC wrote:It would be difficult to get machined as it's 0.9mm difference. The best solution is either a complete ST205 rear subframe(this also increases track width by 25-30mm eliminating the need for spacers) or using just 205 wheel hubs. 185 hub is 54.1 and the 205 is 55mm.
Are the hubs a pain to install?
Any custom work needed?
The rear frames a good idea but I already ordered my rims so I could avoid spacers
205s are extremely rare in Australia
I have seen one in my life
gt4lm
Postby ALLensTRAC » Sun Apr 27, 2014 12:19 am
gt4lm wrote:Are the hubs a pain to install?
Hubs are not terribly difficult to install but I am a master mechanic with 13 years experience so there is not much that is anymore lol! It will require removing the rear spindles and then pressing out the hub. This can be exacerbated by excessive corrosion. It's basically like doing rear wheel bearings as the hub presses into the bearing. Can you order 205 hubs from the dealer in Australia?
Allen
ALLensTRAC
Postby gt4lm » Sun Apr 27, 2014 12:29 am
I should take a look on the way home from work and ask them
Would I need the205 handbrake set up as well? Or can I regal the185 e brake set up ?
gt4lm
Postby gt4lm » Sun Apr 27, 2014 12:48 am
Yep a locating ring that thin would be a difficult job indeed
gt4lm
Postby gt4lm » Sun Apr 27, 2014 1:40 am
This does not look so bad I can't see it killing anyone
http://www.turbocelica.nl/541vs550mm.htm
gt4lm
Postby DeeCee » Sun Apr 27, 2014 2:30 am
Caldina st215 rear hubs can also be used as they are the same as st205 hubs. I used the st215 rear hubs on my car
DeeCee
Postby gt4lm » Sun Apr 27, 2014 7:30 am
DeeCee wrote:Caldina st215 rear hubs can also be used as they are the same as st205 hubs. I used the st215 rear hubs on my car
Thanks for the info
However these are even more rare over here
gt4lm
Postby DeeCee » Sun Apr 27, 2014 8:02 am
actually the point being was that if you are ordering via part numbers, you have two options to find parts around the world for, not just the st205.
As for changing them, you need to use a hydraulic press - would probably pay to change your bearings at the same time. Bearings are the same as the front.
DeeCee
Postby sainz » Sun Apr 27, 2014 9:22 am
i have the rears complete with knuckles ,full bolt on set.
in Victoria Australia.http://www.ebay.com.au/itm/201078214067 ... 1555.l2649
sainz
Postby gt4lm » Sun Apr 27, 2014 11:29 am
sainz wrote:i have the rears complete with knuckles ,full bolt on set.
Would love them but your pricing is in aftermarket price range but glws mate
gt4lm
