Where to buy complete front and rear brake upgrade
Re: Where to buy complete front and rear brake upgrade
Postby sainz » Sun Apr 27, 2014 8:42 pm
show me where i can get after market rears even Taiwanese made brakes complete for this price.
sainz
Postby Corey » Sun Apr 27, 2014 10:02 pm
Check out ksport UK. They make front and rear kits. I have their front 6 pot kit. It bolted on but needed some adjusting to make it fit perfectly.
Corey
Images: 49
Postby gt4lm » Mon Apr 28, 2014 1:05 am
Lol fooling around in the garage an found some alloy hub ring for some old wheels I had
Looking at them the have a 54.1 internal diameter and 60 something outer diameter
It propably won't work but I'll pop over to my mates place and see if he can shove them on his machine and bring them down to 55mm outer diameter which is dead accurate
gt4lm
Postby sainz » Mon Apr 28, 2014 2:27 am
lol 0.45thick spacer.
Go and buy these cheap Taiwanese brakes.
http://www.ebay.com/itm/Ksport-ProComp- ... 80&vxp=mtr
sainz
Postby gt4lm » Mon Apr 28, 2014 3:41 am
sainz wrote:lol 0.45thick spacer.
ill be ok
just found some tube in the exact size and wall thickness i need as opposed to milling down the rings
love fact finding missions
got some 205 rear calipers for a steal and totaly by chance
and will grab some rear dba discs when i get a chance to visit my dealer friend
waiting on a reply in regards to my willwood front kit
gt4lm
Postby sainz » Mon Apr 28, 2014 9:50 am
you know wilwood is not made in usa.
http://www.tradeinfo365.com/NorthAmeric ... ERING.html
sainz
Postby ALLensTRAC » Mon Apr 28, 2014 10:35 am
sainz wrote:you know wilwood is not made in usa.
Honestly not much is made in the US anymore unfortunately. The wilwood calipers have proven themselves time and time again in real motorsports competition. I'd like to see the same from Ksport or D2. The only downfall you here regarding Wilwood is caliper flex although that's not common.
To gt4lm I would also look into an adjustable prop valve as increased pedal travel has been reported with this setup. It looks like you are on the right path though!!
Allen
ALLensTRAC
Postby gt4lm » Tue Apr 29, 2014 3:12 am
Yes it seems the prop valve is a must at that point
Wilwoodbrakes have one as do a few other suppliers
I'm probably going to get solid rear discs and slotted front but will wait till my guy gives me his thoughts befor I run around spending to much
gt4lm
Postby ALLensTRAC » Tue Apr 29, 2014 10:14 am
Personally for a street car I would go with solid face front and rear. Anymore the quality of pads make all the difference and that's where I would spend the money. After installing if you get pad "ghosting" then you may require a different compound. Any slotting and drilling compromises the integrity of the rotor. To me it's not worth it.
Allen
ALLensTRAC
Postby gt4lm » Tue Apr 29, 2014 11:53 am
I'm probably going to get solid rear discs and slotted front but will wait till my guy gives me his thoughts befor I run around spending to much[/quote]
good point you make
i went to far on the gtr and had no cold braking due to my disc and pad choice so i had to ride the brakes for a while in the morning to make temp....... i went to solid front and rear and the right pads and i had some good bite from the time i left home
i will probably go EBC red again as i had a good time with that brand on the gtr
although i hear so many people praising bendix pads so i might check them out as well
gt4lm
