Ground control
Ground control
Postby Mr Alltrac » Thu Jun 05, 2014 1:45 am
Would the ground control sleeve overs work well with stock shocks. I have the rears converted to accept the front inserts.
Mr Alltrac
Re: Ground control
Postby jsd » Thu Jun 05, 2014 2:32 am
That's exactly my setup. The rear at the highest setting ended up lower than the front but it works
jsd
Re: Ground control
Postby Mr Alltrac » Thu Jun 05, 2014 9:06 am
How is the ride? How much did your car drop, even tho it's on the highest setting.
Mr Alltrac
Re: Ground control
Postby jsd » Fri Jun 06, 2014 4:37 am
I think the ride is great, but I can't compare it to the stock ride because I converted it before I got the car running.
This is with the front and rear on highest settings.
jsd
Re: Ground control
Postby Mr Alltrac » Fri Jun 06, 2014 7:52 am
What is your tire size?
Looks like a pretty good stance, rear is definently lower.
Mr Alltrac
Re: Ground control
Postby jsd » Fri Jun 06, 2014 4:39 pm
Thanks I'm running 205/55R16
jsd
