St185 brake caliper replacement
Postby Mr Alltrac » Sat Jul 26, 2014 3:03 pm
Is there any other car that has a relatively good brake setup to replace my st185 calipers.
I know the Porsche calipers and 205.... Etc.
but common cars that can be found in local wrecking yards, will anything fit that could be considered an upgrade?
Mr Alltrac
Re: St185 brake caliper replacement
Postby aus jd 2703 » Sat Jul 26, 2014 10:25 pm
The revolution wilwood kit is good. Add track pads and it up to hard trackdays. Can't fault it.
aus jd 2703
Postby Mr Alltrac » Sun Jul 27, 2014 12:02 am
I would like to get it but I got more to fix so I can't spend 900 on just front brakes. Hopefully one day.
Mr Alltrac
Postby aus jd 2703 » Sun Jul 27, 2014 8:14 am
Ok fair call just keep in mind good pads and rotors plus fluid and braided lines is like $4-700 so you may not save as much as expected.
IMO Porsche 6 piston plus good pads and rotors would be better than wilwoods but it's hard to find and engineer the gear to fit.
I went as far as I could with stock calipers even with ducting I'd cook them in 4-6 laps. Now they don't get close.
aus jd 2703
