Wilwood big brake set up (rear)
Postby MARLON1211 » Wed Aug 06, 2014 3:30 pm
Finally installed the Wilwood rear.
Also here's the link on the Front Wilwood installed.
viewtopic.php?f=8&t=45391
thanks guys
SO BE IT
MARLON1211
Re: Wilwood big brake set up (rear)
Postby lumbercis » Thu Aug 07, 2014 9:29 pm
Nice, you didn't happen to get the weight difference between the two setups did you?
Caldina powered...
lumbercis
Postby MARLON1211 » Fri Aug 08, 2014 12:20 am
to be honest it's a tad heavier due to bigger rotors, but the Wilwood caliper is very light compared to the stock one which it makes up the difference between the two set up. But man the stopping power is amazing its a night and day difference.
SO BE IT
MARLON1211
Postby MWP » Fri Aug 08, 2014 3:30 pm
Cross drilled rotors are such a bad idea.
Really they should be made illegal.
MWP
Postby RafaCalde » Sun Aug 10, 2014 11:35 am
Where did you source the whole setup?
Rafa
1990 White ST185 w/ Carlos Sainz motor, ecu, and tranny
RafaCalde
Postby 88gt4DE » Sun Aug 10, 2014 10:42 pm
Very nice work 8)
Postby MARLON1211 » Sun Aug 10, 2014 11:50 pm
RafaCalde wrote:Where did you source the whole setup?
Revolution makes them. Just call them
SO BE IT
MARLON1211
Postby TheNubkins » Sat May 16, 2015 3:24 am
With this kit were you able to retain your parking brake function?
The Nubkins
-1990 Toyota Celica All-Trac Turbo
-2001 VW Golf TDI
TheNubkins
Postby MARLON1211 » Sat May 16, 2015 4:06 pm
TheNubkins wrote:With this kit were you able to retain your parking brake function?
Yes
SO BE IT
MARLON1211
Postby msanders2 » Sun May 17, 2015 11:57 am
Didn't know revolution made a kit for the rear, only fronts. How much does the rear kit cost?
msanders2
Postby TheNubkins » Sun May 17, 2015 3:14 pm
They don't have it listed because it's more of a special order type deal because they machine the hat to allow you to keep your OEM parking brake. Just got an email back from them. 949 for the front and 1399 for the rear. If you purchase both at once a small discount can be made(or so I was told by Revolution). I'm debating ordering these up right away.
The Nubkins
-2001 VW Golf TDI
TheNubkins
Postby MARLON1211 » Sun May 17, 2015 6:47 pm
TheNubkins wrote:They don't have it listed because it's more of a special order type deal because they machine the hat to allow you to keep your OEM parking brake. Just got an email back from them. 949 for the front and 1399 for the rear. If you purchase both at once a small discount can be made(or so I was told by Revolution). I'm debating ordering these up right away.
Yes your absolutely right. The rotors are custom made that's why it's a little expensive. Cuz our cars have the drum shoe like ebrake they have to hollow out the center disc to accommodate the hand brake setup. That's why is direct bolt on. You can get their cheaper set up but no handbrake function. Im not sure though that the price given to you is with powder coated caliper with slotted crossdrilled rotors oherwise you'll be getting blank rotors with flat black calipers.
SO BE IT
MARLON1211
Postby DeeCee » Mon May 18, 2015 12:13 am
Interesting. Is an mount adapter / dog bone used to mount the Wilwood caliper?
GT Four Adovansu "I want to enjoy the powerful and nimble agility behavior."
Elephant: http://www.alltrac.net/phpBB2/viewtopic.php?t=26687
DeeCee
Postby MARLON1211 » Mon May 18, 2015 12:46 pm
DeeCee wrote:Interesting. Is an mount adapter / dog bone used to mount the Wilwood caliper?
Yes.
SO BE IT
MARLON1211
