interchangeable celica brakes parts
Postby dmlsupra » Thu Oct 16, 2014 1:39 am
I just bought a all trac, but the car will need to pass inspection.
Everything is in great shape with the car, but the brake dust shield (back plate) are rotten and I know this will not pass the inspection. Those plate are no longer available at Toyota, but the one from the 1994-1999 are still available.
My question is if anyone knows if I can fit them on my st-185, or not.
dmlsupra
Re: interchangeable celica brakes parts
Postby yyonline » Fri Oct 17, 2014 10:40 pm
The dust shields for the all-trac are the same as the 92-93 GT, so you may be able to find some in a scrap yard.
Where do you live that dust shields are required for inspection?
yyonline
Postby dmlsupra » Sat Oct 18, 2014 9:36 pm
problem is that they are all rusted out at the scrap yard too.
I order from Toyota a the front from a 1994-1999 GT has the seem similar, so I figured I would probably be able to use them
The car needs to pass inspection, I'm from Quebec and bought the car in Ontario, and everytime you buy a car outside our province, the car need to go to a complete inspection. I know It's crazy, but I have to do it if I want to drive the car.
dmlsupra
Postby underscore » Sun Oct 19, 2014 6:18 am
Do they actually check for little things like dust shields for an OOP out there?
