St185 CV axles????
St185 CV axles????
Postby peteleetzor » Thu Oct 23, 2014 3:53 pm
So im in the process of replacment the axle, hubs, and bearing. I came accorss an issue and Im not sure which one to use for the axle. I did a quick search on Oriley and this came up. The only difference between the 5031 and 5085 is that the lenght for the 5031 is 4 inch shorter then the 5085. Any idea which one I need?
The first item is the Part # : 60-5031
http://www.oreillyauto.com/site/c/detai ... &ppt=C0362
Second item was Part Number: 60-5085
peteleetzor
Re: St185 CV axles????
Postby yyonline » Thu Oct 23, 2014 7:32 pm
60-5031 is a ST185 axle.
yyonline
Postby peteleetzor » Wed Nov 05, 2014 7:16 pm
oriley ended up giving me this
http://www.yoyopart.com/oem/13260438/su ... pplication
it says is for the 88-89 alltrac.
Will this work? or did they mess up. My car does have abs.
peteleetzor
Postby yyonline » Thu Nov 06, 2014 4:31 am
Rockauto lists TO-8030 as an 88-91 Camry axle. Which according to this thread, should work. If in doubt, measure the length and compare it to the old one.
yyonline
Postby ST_6396 » Thu Nov 06, 2014 7:22 am
That axle should work, but it won't have the tone ring for the wheel speed sensor so your ABS wouldn't work.
ST_6396
Images: 2
Postby yyonline » Thu Nov 06, 2014 7:44 am
According to the specs, TO-8030 has the 48-tooth ABS tone wheel, which should work for ST185.
yyonline
Postby FC Zach » Thu Nov 06, 2014 9:42 am
The O'Reilly part #: 60-5031 will work for you and it comes with the ABS ring. I replaced both sides on my car with this part #.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
