ST215 LHD Conversion
Postby Kiesijemmari » Thu Nov 20, 2014 5:31 pm
Hi. I'm considering on buying ST215 GT-T Caldina. Has someone done LHD conversion? What does it take? Do you have to change firewall? Of course you have to lengthen wire harness and change wipers.
Does steering rack bolt straight on?
Thank you already!
Kiesijemmari
Re: ST215 LHD Conversion
Postby GT4_DRED » Thu Nov 20, 2014 7:37 pm
Kiesijemmari wrote:Hi. I'm considering on buying ST215 GT-T Caldina. Has someone done LHD conversion? What does it take? Do you have to change firewall? Of course you have to lengthen wire harness and change wipers.
Thank you already!
I think the biggest question will be, "where do you plan on getting the LHD firewall?" To my knowledge, they were only RHD.
'00 SC300 - "The long way home" daily driver
'88 ST165 - project "Rahtid"
'88 ST165 - Project "Supah Cyat"
'91 MR2
GT4_DRED
Postby Kiesijemmari » Thu Nov 20, 2014 7:42 pm
Avensis ZZT/AT220? Ain't they almost same body? They look like same.
Kiesijemmari
Postby Locker » Thu Nov 20, 2014 8:13 pm
as someone who is in the midst of doing a LHD conversion its best to have a donor car. Lots of little things that are different in the body wiring harness etc. The RHD steering rack will not work and you'll def need the full firewall.
90 ST185
Locker
Postby Kiesijemmari » Thu Nov 20, 2014 8:28 pm
Of course I will get donour car, I'm just trying to ask if someone has already done LHD conversion and has any tips or to-do guides
So there isn't place for steering column on left side of firewall?
I know that rhd rack won't work but I tried to ask if Avensis LHD rack bolts straight in origina place or do I have to do new holes ect
Kiesijemmari
Postby Locker » Thu Nov 20, 2014 8:35 pm
We don't have either of those cars here in North America so as far as the looks of the firewalls I'm zero help. In the case of my celica the firewall's were completely different and there was no hope of not having to replace it.
Good luck!
90 ST185
Locker
